Not sure where else to post this, but had issue when upgrading to 1.22.1.4200.
Downgraded back to 1.22.0.4163 and running again.
Sharing for awareness.
Pi Server Info
Linux hostname 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l
description: ARMv7 Processor rev 3 (v7l)
product: Raspberry Pi 4 Model B Rev 1.1
serial: 100000008fc0a1b7
width: 32 bits
After install completed, Plex not available.
Rebooted server, Plex still not available.
Downgraded back to plexmediaserver_1.22.0.4163-d8c4875dd_armhf.deb
Rebooted server, Plex is available again.
In case of corrupted .deb download, I removed plexmediaserver_1.22.1.4200-c073686f2_armhf.deb and downloaded a fresh copy.
Installed fresh plexmediaserver_1.22.1.4200-c073686f2_armhf.deb
Same result, Plex not available.
Downgraded to plexmediaserver_1.22.0.4163-d8c4875dd_armhf.deb
Rebooted server, Plex available.
Output of
‘/usr/lib/plexmediaserver/Plex Media Server’
$ ‘/usr/lib/plexmediaserver/Plex Media Server’
Error in command line:the argument for option ‘–serverUuid’ should follow immediately after the equal sign
Crash Uploader options (all are required):
–directory arg Directory to scan for crash reports
–serverUuid arg UUID of the server that crashed
–userId arg User that owns this product
–platform arg Platform string
–platformVersion arg Platform version string
–vendor arg Vendor string
–device arg Device string
–model arg Device model string
–sentryUrl arg Sentry URL to upload to
–sentryKey arg Sentry Key for the project
–version arg Version of the product
–allowRetries arg Whether we will allow retries
Error: Unable to set up server: listen: Address already in use (N5boost10wrapexceptINS_6system12system_errorEEE)
1.22.1.4200 has also failed on my raspberry pi. Here’s what I’m seeing from running sudo systemctl status plexmediaserver:
plexmediaserver.service - Plex Media Server
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2021-03-17 14:17:39 PDT; 3min 22s ago
Process: 11409 ExecStart=/bin/sh -c export PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-release | awk -F= "{print \$2}" | tr -d \" )"; export PLEX_MEDIA_SERVER_INFO_DEVICE="PC"; e
Process: 11405 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" (code=exited, status=0/
Main PID: 11409 (code=exited, status=127)
Mar 17 14:17:34 raspberrypi systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
Mar 17 14:17:39 raspberrypi systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
Mar 17 14:17:39 raspberrypi systemd[1]: Stopped Plex Media Server.
Mar 17 14:17:39 raspberrypi systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Mar 17 14:17:39 raspberrypi systemd[1]: Failed to start Plex Media Server.
Mar 17 14:17:39 raspberrypi systemd[1]: plexmediaserver.service: Unit entered failed state.
Mar 17 14:17:39 raspberrypi systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
And from journalctl -xe | grep -i plex:
Mar 17 14:17:34 raspberrypi systemd[1]: Starting Plex Media Server...
-- Subject: Unit plexmediaserver.service has begun start-up
-- Unit plexmediaserver.service has begun starting up.
Mar 17 14:17:34 raspberrypi systemd[1]: Started Plex Media Server.
-- Subject: Unit plexmediaserver.service has finished start-up
-- Unit plexmediaserver.service has finished starting up.
Mar 17 14:17:34 raspberrypi Plex Media Server[11409]: /usr/lib/plexmediaserver/Plex Media Server: error while loading shared libraries: libicudataplex.so.67: cannot open shared object file: No such file or directory
Mar 17 14:17:34 raspberrypi systemd[1]: plexmediaserver.service: Main process exited, code=exited, status=127/n/a
Mar 17 14:17:34 raspberrypi systemd[1]: plexmediaserver.service: Unit entered failed state.
-- Subject: Unit plexmediaserver.service has finished shutting down
-- Unit plexmediaserver.service has finished shutting down.
-- Subject: Unit plexmediaserver.service has failed
-- Unit plexmediaserver.service has failed.
Mar 17 14:21:02 raspberrypi sudo[11609]: root : TTY=pts/0 ; PWD=/root ; USER=root ; COMMAND=/bin/systemctl status plexmediaserver
Attempting to upgrade to: 1.22.1.4200-c073686f2
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
Selecting previously unselected package plexmediaserver.
(Reading database … 7262 files and directories currently installed.)
Preparing to unpack /tmp/plexmediaserver.deb …
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Docker detected. Preinstallation validation not required.
Unpacking plexmediaserver (1.22.1.4200-c073686f2) …
Setting up plexmediaserver (1.22.1.4200-c073686f2) …
PlexMediaServer install: Docker detected. Postinstallation tasks not required. Continuing.
Processing triggers for libc-bin (2.31-0ubuntu9.1) …
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Then for the docker image itself it says “unhealthy,” whatever that means.
Have the same issue on Raspberry Pi 4. Upgrading to 1.22.1.4200 makes the server unavailable. I waited several hours after the update, rebooted the device, waited more, but no luck. I had to downgrade to a “stable” version.
