Upgrading WebGalleryOfArt
it’s been a while since I had written the first Web Galler Of Art plugin. Framework is now version 2 and simply dropping in a bundle no longer works. I use this advice to activate developer mode (server returns a blank page so it’s hard to tell if the Gods have granted me access)
http://forums.plexapp.com/index.php/topic/34613-developer-mode/
I would like to update the catalog and have the plugin usable again.
My Info.plist looks like this
<br />
?xml version="1.0" encoding="UTF-8"?><br />
<!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"><br />
<plist version="1.0"><br />
  <dict><br />
    <key>CFBundleDevelopmentRegion</key><br />
    <string>English</string><br />
    <key>CFBundleExecutable</key><br />
    <string/><br />
    <key>CFBundleIdentifier</key><br />
    <string>com.plexapp.plugins.webgalleryofart</string><br />
    <key>CFBundleInfoDictionaryVersion</key><br />
    <string>6.0</string><br />
    <key>CFBundlePackageType</key><br />
    <string>AAPL</string><br />
    <key>CFBundleSignature</key><br />
    <string>hook</string><br />
    <key>CFBundleVersion</key><br />
    <string>1.0</string><br />
    <key>PlexClientPlatforms</key><br />
    <string>*</string><br />
    <key>PlexFrameworkVersion</key><br />
    <string>2</string><br />
    <key>PlexPluginMode</key><br />
    <string>AlwaysOn</string><br />
    <key>PlexPluginConsoleLogging</key><br />
    <string>1</string><br />
    <key>PlexPluginDevMode</key><br />
    <dict><br />
      <key>Web Gallery Of Art</key><br />
      <dict><br />
        <key>URLPattern</key><br />
        <string>.*wga\.hu.*</string><br />
        <key>LinkedPlugin</key><br />
        <key>TestURLs</key><br />
        <array><br />
          <string>http://www.wga.hu/html/a/aachen/j_couple.html</string><br />
        </array><br />
      </dict><br />
    </dict><br />
  </dict><br />
</plist><br />
I have a VERSION file containing a single number. Did I omit anything else?
My problem is that the server remains oblivious to my plugin. No traces in the system.log / nothing.
Any suggestions welcome!
JP
Hey, it might be because your plist is invalid. You are attempting to specify a local URL service but not including the appropriate “PlexURLServices”. Have a look at this example, see if that helps: https://github.com/plexinc-plugins/TWiT-Live.bundle/blob/master/Contents/Info.plist
