Using 2 network adapters no option to choose which?
I have 2 network adapters on my machine that use two different IP ranges and subnets. They both connect to the internet trough 2 different WAN modems. Is there no way to get Plex Media Server to specifically run on an adapter of your choosing. I can see that you can pick a port number but not the interface it uses??
Hope there's enough info there for someone to explain how I can achieve this or tell me it's not possible.
Correct. It is not possible
You can search the forums for multiple NICs or binding and read previous discussions on the subject. There are some posts that advise on having gateway defined for the one you want Plex Media Server to use but not the other
sa2000 is correct.
multiple subjects on the forums
Christmas has come early ! The feature of allowing the user to select a specific network interface is now available as from Plex Media Server version 1.13.5.5291 which was released to Plex Pass beta yesterday
See Release Note Plex Media Server
  • Allow picking a specific network address to bind to (#8492)
Details of the new Advanced Network server setting can be found on this support article https://support.plex.tv/articles/200430283-network/
Please pay attention to the associated notes
