I’m trying to use hardware acceleration inside my docker container (using wernight/plex-media-server:autoupdate image) and it fails.
I have a AMD HD6950 and an Intel i7-2700k iGPU. I know that plex will not work on the AMD card, but I’d like to use the iGPU.
Note that my motherboard does not have an output for the iGPU.
Here is the output of sudo lshw -c video on the host and inside the container:
*-display
description: VGA compatible controller
product: Cayman PRO [Radeon HD 6950]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:04:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
configuration: driver=radeon latency=0
resources: irq:50 memory:e0000000-efffffff memory:f7d20000-f7d3ffff ioport:d000(size=256) memory:f7d00000-f7d1ffff
*-display
description: Display controller
product: 2nd Generation Core Processor Family Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm bus_master cap_list
configuration: driver=i915 latency=0
resources: irq:53 memory:f7000000-f73fffff memory:d0000000-dfffffff ioport:f000(size=64)
Here is the output of lsmod | grep i915 on the host:
i915 1232896 0
i2c_algo_bit 16384 2 i915,radeon
drm_kms_helper 155648 2 i915,radeon
drm 364544 5 ttm,i915,drm_kms_helper,radeon
video 40960 2 i915,asus_wmi
Here is the output of lspci | grep VGA on the host and inside the container:
04:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cayman PRO [Radeon HD 6950]
Inside the container, vainfo gives me the following output:
vainfo
error: XDG_RUNTIME_DIR not set in the environment.
error: can’t connect to X server!
libva info: VA-API version 0.39.4
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/gallium_drv_video.so
libva info: va_openDriver() returns -1
vaInitialize failed with error code -1 (unknown libva error),exit
My container has --device=/dev/dri:/dev/dri and I also did a chmod -R 777 /dev/dri (I know it’s bad practice, just trying to test things out).
If anyone has any clue, I’d really appreciate some help!
