Hi everyone,
Firstly glad to hear there's an update coming soon for MKV and Music - amazing!
Now, i am having a few issues which are becoming annoying, apologies if mentioned somewhere else..
1. Sometimes when starting a movie it begins at the time the previous movie ended. As you can imagine its annoying when you see the end of a movie you haven't seen!
2. Frequently, like 90% of the time, after say looking a movies description and going back to the library list, half the covers go grey are and inaccessible. You have to go back another level and then go back into the library to see them again.
3. Sometimes, seems randomly video pauses and sound seems to continue, then skips ahead, so much so that when it does it i have to rewind what im watching for a couple mins then watched what it skipped.
Cheers
1. Check this thread: [Starting Video Half Way Through](https://forums.plex.tv/topic/138261-starting-video-half-way-through/)
2. Can't find the thread offhand, but this issue (or similar) has been reported to the devs and they have responded IIRC.
3. I've seen this once or twice as well. I know it's difficult, but if you could get some PMS logs when this happens it will likely help the devs with troubleshooting (same could be said of the above as well).
Thanks for the reply, seems they are aware of #1 and working on it. 2# is most annoying and hopefully they are working on that too. For 3, i'll try some tests to see if i cant get more detail, doesnt do it all the time so could be other network influences going on or something on my laptop that is the server.
Roll on the new update!
Same issue with sometimes starting movies in credits.
