Server Version#: 1.25.7.5604-980a13e02
Player Version#: Client version 5.33.1
Frasier XML info.zip (1.8 KB)
Plex Media Server Logs_2022-03-20_15-56-11.zip (2.9 MB)
Hi. I’ve never had a single problem playing any hevc file on my LG CX, including 4k remuxes with massive bitrates. I have Plex Pass and hardware transcoding enabled with a Pascal Titan X (but never need to use it myself). I have gigabit ethernet. Here’s my problem…
For some reason, only when I play episodes of Frasier, at specific parts of certain episodes, the video will freeze while the audio continues playing. After 10-15 seconds, the video goes into hyper speed mode and speeds up super quick to catch up to the audio. This only happens at specific parts of certain episodes, and is completely repeatable in every instance. The file is mkv, hevc, 720p, 5.3 mbps, ac3. Nothing about this is unsupported on the LG CX. I’ve never had a problem with any other video. I only direct play files. The file is not transcoding.
This same file plays perfectly fine (direct play) on every other Plex app on every other device I have. It works on my iphone, my macbook air, my PC, and on VLC - zero problems. It’s only on the LG CX.
I can get it to not get this freezing problem on the CX by manually making the video transcode, by changing it from original 720p 5.5 mbps, to 720p 4 mbps. The video then transcodes from mkv to mpgets, hevc to h264, ac3 to aac.
Again, every other device direct plays this fine. My CX direct plays every other video I have that is hevc and ac3 with no problem.
What could I do to fix this? I uploaded my logs and the show’s XML file. In the logs, the problem begins (local time) at about 3:55:08 and continues until about 3:55:19.
