Video Libraries Need Option NOT To Store Track Progress (Like Music Libraries)
Like other Plex users, I’ve painstakingly collected, enhanced and improved thousands of video files over time. For me, it’s music videos from the 80s-90s. And I’d like the ability to watch music videos stored in my collection the same way music is played in Plex - namely that the next music video in the queue starts playing at the beginning of the video - not at the last place the music video was viewed a yesterday, last month or a year, 2 years ago.
The switch for this behavior already exists in Plex - and is called ‘Store Track Progress.’ But it only exists in Music Libraries, not Video Libraries (see below).
Plex - Music Library Feature Missing from Video Libraries
Adding this Music Library feature to Video Libraries would provide control for the media collectors whether Plex ‘forgets’ track progress so all music videos can start at the beginning of the track - just like Plex music does today.
Without this feature, every time a music video is skipped before it ends, the video will restart in the middle or the end next time it is played. For movies and family video libraries, this behavior makes sense - you want restart at the last stopped position. For music-based files (like MP3s, FLAC, WAV) and music videos (MPG, VOB, MP4, MKV, etc.) it doesn’t.
The problem compounds over time as more and more music videos have been skipped. Eventually, you can’t start any music video at the beginning since they all start midway or near the end every time.
As a workaround, I’ve tried to mark all music videos as “Mark As Unplayed” - but there’s no Select All feature to do this across thousands of files at once. I’ve attempted to reverse engineer the “Store Track Progress” functionality via hacked code to no avail. I’m attempting to write a script to alter the Plex DB contents to erase the track progress for all music videos on a regular basis - none of which are good or supported options.
If the “Store Track Progress” feature from Music Libraries could be added to Video Libraries (and enabled by default for all users), those collectors of music videos could ‘watch’ music videos the way MTV, VH1 played videos - and how everyone listens to their music. An alternative workaround would be a ‘select all’ feature that allows me to mark all selected library content as ‘Unplayed’ would work too.
Thanks, Plex. And keep up the great work!
There’s no ‘select all’ button, but you can select multiple items to toggle them all at once.
Very helpful @beckfield! With the select all feature, I can effectively workaround this by using the ‘Toggle Played’ option in the edit bar.
Good stuff. Still hoping this feature in music libraries can be added to video libraries to make this a mainstream design and not a manual workaround.
Thanks!
I would love to see this as well, for exactly the same reason.
If we want to get attention to this issue, we need people to sign into their Plex Forums account and click the VOTE button in the upper left-hand corner to add one or more of their votes to push this up the list of priorities.
YES! I too would want to disable the Store Track Progress in video libraries.
There are lots of other posts about this too. Just search for disable resume.
For my use case, we are using Plex to show educational lesson videos and music videos for kids.
So, a teacher will setup a playlist, often previewing and partially playing the videos to check the playlist.
But, when time comes to show the videos ‘for real’, the videos can start mid-way, which is NOT desirable.
For example, Jellyfin has a global setting to configure thresholds for resuming playback (see attached screenshot)
If that were implemented in Plex, I would be happy. I could just set the “Minimum resume percentage” to 100%. Or set the “Minimum resume duration” to some large time to effectively disable resume playback.
But, other users might want this to be a per library setting instead of global.
i’m shocked, surprised, saddened, and disappointed to find that this is a ‘thing’… I just turned Store Track Progress OFF on my Music Library; i thougth i needed to adjust something to see it on my Videos Library, I didn’t once think it wouldn’t be available AT ALL!?! storing track progress for videos, especially Music Videos, is no good, Please Fix This, Thank You!!! VOTEDDDD!!!
Would be great if we redirected those with a need for this to VOTE here to raise visibility - and the possibility - of a fix.
This is a must-have for me to be able to use Plex for music videos, especially when using random playlists.
