Video playback Slow and interrupted
It seems that no matter which camera/device I use to capture videos, when played from my Plex server no matter which device I use (IPhone, Mac, iPad, Windows) all of the videos play for a bit and then stop and then start again and then stop, etc…
It seems like I can’t get any video to play straight through. I admit that I try for videos that are sharp, but net result is suppose to show how sharp they are.
Is there some setting that I need to change in order for these videos to run smoothly?
Can you supply the server logs please ?
(Settings - Server - TroubleShooting - Download Logs)
It will provide you with a ZIP file.
Attach that ZIP file here.
I suspect the videos are transcoding and, knowing Synology, the CPU isn’t fast enough to transcode in real time.
