Video Playlists and Format Question
MythTV Channel - development
I have got my MythTV channel working now against my MythTV installation.
However, when Myth sets up a recording for streaming, it presents the results back in playlist files m3u
1st it returns a m3u with 2 choices on low and higher bandwidth
selecting one of the redirects in 1st
2nd returns a list of 'n' .ts urls representing the transcoded format.
I can't, however, seem to get the Plex Server to recognise the URL of either the m3u or ts formats to add as the media url for VideoClipObject.
Any suggestions pls.
Paul
2012-06-10 00:48:32,839 (3640) :  INFO (core:337) - No user preferences file exists<br />
2012-06-10 00:48:32,852 (3640) :  DEBUG (core:337) - 2nd options line count: 113<br />
2012-06-10 00:48:32,854 (3640) :  DEBUG (core:337) - 2nd options line 0: #EXTM3U<br />
2012-06-10 00:48:32,854 (3640) :  DEBUG (core:337) - 2nd options line 1: #EXT-X-TARGETDURATION:10<br />
2012-06-10 00:48:32,855 (3640) :  DEBUG (core:337) - 2nd options line 2: #EXT-X-MEDIA-SEQUENCE:1<br />
2012-06-10 00:48:32,855 (3640) :  DEBUG (core:337) - 2nd options line 3: #EXTINF:10<br />
2012-06-10 00:48:32,857 (3640) :  DEBUG (core:337) - 2nd options line 4: /Content/GetFile?StorageGroup=Streaming&FileName=1002_20120504220000.mpg.640x368_800kV_64kA.av.000001.ts<br />
2012-06-10 00:48:32,858 (3640) :  DEBUG (prefskit:390) - Reloading user prefs due to mtime change (None --> 0).<br />
2012-06-10 00:48:32,858 (3640) :  INFO (core:337) - No user preferences file exists<br />
2012-06-10 00:48:32,859 (3640) :  DEBUG (prefskit:390) - Reloading user prefs due to mtime change (None --> 0).<br />
2012-06-10 00:48:32,861 (3640) :  INFO (core:337) - No user preferences file exists<br />
2012-06-10 00:48:32,861 (3640) :  DEBUG (core:337) - Media URL is http://192.168.1.90:6544/Content/GetFile?StorageGroup=Streaming&FileName=1002_20120504220000.mpg.640x368_800kV_64kA.av.000001.ts<br />
2012-06-10 00:48:32,868 (3640) :  DEBUG (core:337) - No service found for URL 'http://192.168.1.90:6544/Content/GetFile?StorageGroup=Streaming&FileName=1002_20120504220000.mpg.640x368_800kV_64kA.av.000001.ts'<br />
2012-06-10 00:48:32,868 (3640) :  DEBUG (core:337) - No matching services found for 'http://192.168.1.90:6544/Content/GetFile?StorageGroup=Streaming&FileName=1002_20120504220000.mpg.640x368_800kV_64kA.av.000001.ts'<br />
2012-06-10 00:48:32,871 (3640) :  DEBUG (servicekit:145) - There are 1 fallback services<br />
2012-06-10 00:48:32,872 (3640) :  DEBUG (core:337) - Loading service code for Fallback (URLServiceRecord)<br />
2012-06-10 00:48:32,992 (3640) :  DEBUG (prefskit:163) - Loading prefs for <Framework.policies.servicepolicy.ServicePolicy object at 0x05175C30><br />
2012-06-10 00:48:32,993 (3640) :  INFO (core:337) - No user preferences file exists<br />
2012-06-10 00:48:33,000 (3640) :  CRITICAL (core:337) - Function named 'NormalizeURL' couldn't be found in the current environment<br />
2012-06-10 00:48:33,002 (3640) :  WARNING (core:337) - Unable to normalize URL 'http://192.168.1.90:6544/Content/GetFile?StorageGroup=Streaming&FileName=1002_20120504220000.mpg.640x368_800kV_64kA.av.000001.ts'<br />
2012-06-10 00:48:33,005 (3640) :  DEBUG (core:337) - No service found for URL 'http://192.168.1.90:6544/Content/GetFile?StorageGroup=Streaming&FileName=1002_20120504220000.mpg.640x368_800kV_64kA.av.000001.ts'<br />
2012-06-10 00:48:33,016 (3640) :  CRITICAL (core:337) - Exception when constructing response (most recent call last):<br />
  File "C:\Users\Paul\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\components\runtime.py", line 874, in construct_response<br />
    resultStr = self._core.data.xml.to_string(result._to_xml(context=context))<br />
  File "C:\Users\Paul\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\api\objectkit.py", line 374, in _to_xml<br />
    el = Framework.modelling.objects.ModelInterfaceObjectContainer._to_xml(self, context)<br />
  File "C:\Users\Paul\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\modelling\objects.py", line 351, in _to_xml<br />
    root = Container._to_xml(self, context)<br />
  File "C:\Users\Paul\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\modelling\objects.py", line 124, in _to_xml<br />
    self._append_children(root, self._objects, context)<br />
  File "C:\Users\Paul\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\modelling\objects.py", line 130, in _append_children<br />
    el = obj._to_xml(context)<br />
  File "C:\Users\Paul\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\api\objectkit.py", line 310, in _to_xml<br />
    if urlservice._media_objects_function_for_url_is_deferred(url):<br />
  File "C:\Users\Paul\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\api\servicekit.py", line 87, in _media_objects_function_for_url_is_deferred<br />
    return self._media_objects_function_for_service_is_deferred(service)<br />
  File "C:\Users\Paul\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\api\servicekit.py", line 90, in _media_objects_function_for_service_is_deferred<br />
    return self._function_for_service_is_deferred(service, 'MediaObjectsForURL')<br />
  File "C:\Users\Paul\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\api\servicekit.py", line 93, in _function_for_service_is_deferred<br />
    ret = self._core.services._function_in_service_is_deferred(f_name, service, context=self._context)<br />
  File "C:\Users\Paul\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\core.py", line 1021, in _function_in_service_is_deferred<br />
    return service.host.function_is_deferred(fname, self._create_service_context(service.host, context))<br />
AttributeError: 'NoneType' object has no attribute 'host'<br />
<br />
2012-06-10 00:48:33,017 (3640) :  DEBUG (core:337) - Unable to handle response type: <class 'Framework.modelling.objects.MediaContainer'><br />
2012-06-10 00:48:33,023 (3640) :  DEBUG (core:337) - Response: 500<br />
The plugin framework handles m3u playlists using the HTTPLiveStreamURL() callback. You should be able to implement your code something along the lines of:
<br />
stream = VideoClipObject(<br />
	items=[<br />
		MediaObject(<br />
			parts=[<br />
				PartObject(<br />
					key=HTTPLiveStreamURL(HI_RES_URL.m3u)<br />
					)<br />
				]<br />
			),<br />
		MediaObject(<br />
			parts=[<br />
				PartObject(<br />
					key=HTTPLiveStreamURL(LO_RES_URL.m3u)<br />
					)<br />
				]<br />
			)<br />
		]<br />
	)<br />
Adding them both as MediaObjects to the same VideoClipObject will allow the Plex client to choose the appropriate quality based on global settings.
