Videos and Tracks not playing - possible transcoder issue
Server Version#: 1.32.7.7621
Player Version#: WEB
I’m having an issue where certain tracks aren’t playing in PlexAmp however they work fine in the standard app and web client.
Doing some digging it seems to only be the OPUS transcoded files, and if I set the quality to the highest I have no issues.
I’m not really sure what I’m looking for in the logs but the following errors/warnings appear:
[Req#1662/Transcode/b1b0dff7-22d0-49e7-a890-f5bbb5d29618-1378/4d54be4a-4ca6-4724-936c-46d8a6fda3e9] Unknown decoder ‘mp3’
[CERT] TLS connection from [::ffff:77.44.22.241]:49915 came in with unrecognized plex.direct SNI name
[TranscodeOutputStream] Streaming Session 0x7f78da9818 appears to have died from under us
I’m also having issues with videos playing but I just get the following:
[CERT] TLS connection from XXXX49816 came in with unrecognized plex.direct SNI name ‘XXXXX.plex.direct’; using installed plex.direct cert
Some TV Shows play fine - but most do not load at all.
This is all hosted on my Raspberry Pi4 Server - I did recently move the metadata from the SD card to my SSD and reinstalled Plex. I’m running plex as root in the config file, so I don’t think it’s a permission issue
