Videos on sd-card
if i use a 32GB sd-card for Rasplex, is it possible to save videos on it to watch “offline”?
i saw same Network shares from Rasplex and think about store some videos for my holiday trip.
I know from the Android app, that you can switch between servers and Local Media…
Thx for your help.
Baschtl
Thx for your help.
Baschtl
Only if you load up the Plex Black Edition skin, it has an option to Play File, enable it in Preferences.
Regards
thx, i will try tomorrow…
Hi, I’m again. I found the option…
A window opens and I can navigate through file system… USB drive too.
But when I select a mp4 video it won’t start…
What I’m doing wrong?
Hmm… You’re right, I haven’t used this for over a year, will contact @DeadEyeFlint to see if he can shed any light on this.
Regards
Thank you… Is it possible to implement the “open file” to the standard skin?
Done in next release, coming soon.
Regards
Wow yeah! Thank you very much!
Then i can fill my sd-card for holiday :wink:
