Server Version#:
In the past week or so, I am now having an issue of frequent stuttering with most TV shows I am currently watching. I checked and there are no frames lost. I’ve realized that if I exit the video, then resume playing again after a second or two, it solves the issue (temporarily).
I am using a DS918+.
I haven’t been able to find an answer anywhere else, so I am coming here in hopes you may have one!
Just to note, I have recently cleaned my Synology NAS of all particles and dust.
I am having the same issue with both my Xbox Series X and my Roku Ultra. It seems more common with 1080p content. I use direct play. I have had the same setup for years but in the last couple days 1080p suddenly “jitters” every 10 seconds or so and then with freeze frame but audio will continue.
Some is seriously messed up in the most recent release.
plex.log (87.8 KB)
I have attached a log, it looks like the Roku is transcoding and not using Direct Play
Dec 11, 2023 13:25:41.257 [0x700004d69000] DEBUG - [Req#17266/Transcode] MDE: tv.plex.agents: Direct Play is disabled
Dec 11, 2023 13:25:41.257 [0x700004d69000] DEBUG - [Req#17266/Transcode] MDE: tv.plex.agents: Audio Direct Streaming is disabled, so video’s audio stream will be transcoded
Dec 11, 2023 13:25:41.257 [0x700004d69000] DEBUG - [Req#17266/Transcode] MDE: Cannot direct stream audio stream due to profile or setting limitations
Dec 11, 2023 13:25:41.257 [0x700004d69000] DEBUG - [Req#17266/Transcode] MDE: tv.plex.agents: selected media 0 / 365769
Dec 11, 2023 13:25:41.257 [0x700004d69000] DEBUG - [Req#17266/Transcode] Streaming Resource: Added session 0x7fd0e6471b48:d1e0a1223329acf07e68b6ea99b2d4e3
Dec 11, 2023 13:25:41.257 [0x700004d69000] DEBUG - [Req#17266/Transcode] Streaming Resource: Reached Decision id=35152 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=365769 part=(id=367286 decision=transcode protocol=http streams=(Audio=(id=764788 decision=transcode bitrate=320 encoder=libmp3lame channels=2 rate=44100))))
So confusing, I have 2 Roku Ultras using the same network with the same server and the same file. One plays perfectly, one drops frames and eventually freezes up.
I also use direct play (just checked to confirm) with the content I watch via Plex on my Xbox Series X, which is almost universally all 1080p as well.
I hope there is a fix or update soon; my smart TV has a controller with issues (making selecting anything on Plex a huge chore), and my only other option is my old Xbox One, which I would have to set up again.
The factory reset of the Roku fixed the issue. My confusion over direct is that it looked from the logs it was NOT direct play but in the Web Portal, it showed DirectPlay working. I dunno.
