Viewing live HD programming stops and starts in 2 second intervals, SD is fine
I did that, no change. I still am getting "the server is not powerful enough " message when I try to play a recorded program in the web player and my iPad. These functions were working just fine in a My Cloud Home that I just returned because one could not update the PMS unless WD did a firmware update. I "upgraded " to this Synology for its faster processor and real app support. I can still return it if it will not do the job. Please let me know,
Steve
Plex Media Server Logs_2020-04-28_22-09-08.zip (4.1 MB)
I can see why it’s stopping… It has no hardware for the MPEG2 + closed captions.
Is there anything you have without closed captions?
pr 28, 2020 21:48:11.991 [0x7f975911f700] DEBUG - MDE: Selected protocol hls; container: mpegts
Apr 28, 2020 21:48:11.991 [0x7f975911f700] ERROR - Unable to find title for item of type 5
Apr 28, 2020 21:48:11.991 [0x7f975911f700] DEBUG - MDE: analyzing media item -1
Apr 28, 2020 21:48:11.991 [0x7f975911f700] DEBUG - MDE: : no direct play video profile exists for http/mpegts/
Apr 28, 2020 21:48:11.991 [0x7f975911f700] DEBUG - MDE: : no direct play video profile exists for http/mpegts//
Apr 28, 2020 21:48:11.991 [0x7f975911f700] DEBUG - MDE: : selected subtitle stream  has no codec
Apr 28, 2020 21:48:11.991 [0x7f975911f700] DEBUG - MDE: : codec is unavailable for analysis
Apr 28, 2020 21:48:11.991 [0x7f975911f700] DEBUG - MDE: : selected media 0 / -1
Apr 28, 2020 21:48:11.991 [0x7f975911f700] DEBUG - Cleaning directory for session 3d3c190a-d6e0-4063-94a0-bac78ddb1190 ()
Apr 28, 2020 21:48:11.991 [0x7f975911f700] DEBUG - Starting a transcode session 3d3c190a-d6e0-4063-94a0-bac78ddb1190 at offset -1.0 (state=3)
Apr 28, 2020 21:48:11.991 [0x7f975911f700] DEBUG - Streaming Resource: Added session 0x7f9750047000:3d3c190a-d6e0-4063-94a0-bac78ddb1190
Apr 28, 2020 21:48:11.991 [0x7f975911f700] DEBUG - TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Apr 28, 2020 21:48:11.992 [0x7f975911f700] DEBUG - TPU: hardware transcoding: final decoder: , final encoder:
Apr 28, 2020 21:48:11.992 [0x7f975911f700] DEBUG - Job running: EAE_ROOT='/volume1/Plex/tmp_transcoding/pms-c957070e-39fc-4368-8650-5c98a022221b/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/volume1/Plex/Library/Application\ Support/Plex\ Media\ Server/Codecs/99c90e0-3095-linux-x86_64/' XDG_CACHE_HOME='/volume1/Plex/Library/Application Support/Plex Media Server/Cache' XDG_DATA_HOME='/volume1/@appstore/Plex Media Server/Resources' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/volume1/@appstore/Plex Media Server/Plex Transcoder' '-noaccurate_seek' '-ignore_unknown' '-scan_all_pmts' '-1' '-rw_timeout' '30000000' '-reconnect' '1' '-reconnect_streamed' '1' '-reconnect_delay_max' '30' '-fflags' '+discardcorruptts+fillwallclockdts' '-probesize' '20000000' '-i' 'http://192.168.1.126:5004/auto/v4.1' '-map' '0:V?' '-codec:V' 'copy' '-map' '0:a?' '-codec:a' 'copy' '-map' '0:s?' '-codec:s' 'copy' '-break_non_keyframes' '1' '-segment_format' 'mpegts' '-f' 'ssegment' '-individual_header_trailer' '0' '-segment_time' '1' '-segment_start_number' '0' '-segment_time_delta' '0.25' '-segment_list' 'http://127.0.0.1:32400/video/:/transcode/session/3d3c190a-d6e0-4063-94a0-bac78ddb1190/07cf1c50-0b69-4f55-bb75-5b39dafed529/seglist?X-Plex-Http-Pipeline=infinite' '-segment_list_type' 'csv' '-segment_list_size' '5' '-segment_list_separate_stream_times' '1' '-segment_list_unfinished' '1' '-max_delay' '5000000' '-map_metadata' '-1' '-map_chapters' '-1' 'media-%05d.ts' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-xioerror' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/3d3c190a-d6e0-4063-94a0-bac78ddb1190/07cf1c50-0b69-4f55-bb75-5b39dafed529/progress'
Apr 28, 2020 21:48:12.005 [0x7f9780c0a700] DEBUG - HTTP 200 response from GET http://192.168.1.126:80/lineup_status.json
Apr 28, 2020 21:48:12.006 [0x7f975911f700] DEBUG - Jobs: Starting child process with pid 810
Please play regular H.264 content so I can verify the hardware is engaging.
I am not sure what “regular H.264” is. The reason I got Plex is for recording Over The Air TV broadcasts and then watching them on my schedule and being able to bypass commercials. I am not sure, but I think that OTA broadcasts are MPEG2, right? I am using an HD Homerun Quattro tuner. This whole issue of transcoding, as I understand it, is the act of converting files from one format to another. Like MPEG2 to H.264, right? As far as I know, no transcoding is required when the file that has been recorded is in the same format as the application that will be playing it requires. That being the case, I do not know of any files that I have that would be H.264. I think that transcoding would be required to play OTA broadcast TV through Plex on my iPad, Correct?
I am not trying to be obtuse, I just do not know how to carry out your request.
I still do not know how to perform the test. What is an example of an H.264 file? Can I produce one on my iPad? I really do not care (much) about live TV. I used it as the easiest example of determining if my plex was set up correctly. What I DO care about is the fact that I can not do anything from my iPad. (see previous screenshot) I suspect that I have a setting that is incorrect somewhere. I have not seen these symptoms elsewhere in the forum regarding Synology. If there is something in this particular NAS that will not let it work properly, I need to return it. But I would hate to do so if it is just because I did not configure it correctly.
Thanks for helping me through this, Steve
