Viewing Plex Server Logs on QNAP using Tautulli
I have Plex Media Server and Tautulli installed on my QNAP NAS and they are both working fine.
I have tried to configure Tautulli so that it can read the Plex Media Server Logs.
Using WINSCP on Windows I can access the log files which are located at :-
/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Logs/
I have entered this path into Tautulli Settings - Plex Media Server - Logs Folder but when I then try to see the file using View Logs it reports No Information Available and the Tautulli Log reports :-
Unable to open Plex Log file. [Errno 2] No such file or directory: ’ /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Logs/Plex Media Server.log’
Am I missing something obvious? I have checked the address numerous times. I have cut and pasted the address from WINSCP all to no avail.
Any help or suggestions would be much appreciated.
Did you try without the trailing slash?
I did - still didn’t work. Just can’t figure it out
It’s there 4 sure, so might have to ask the dev of it, if it can handle like a space, in case below doesn’t work
/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex\ Media\ Server/Logs
Note in above, the backslash before each space to escape it
To locate the relevant support thread, go here:
The slashes didn’t work either I’m afraid.
Thanks for pointing me in the direction of the Tautulli forum section.
I’ve posted the query there too.
