Visible enhancement and play-selection of "Versions"
any chance to implement the following?
Kind of visible sign in the movie detail view - like the trailer button - if a movie has different versions. (stored in the movie folder)
And:
Adding probably the file title to the pop-up which shows up, before selecting the version to play.
Example, I have a movie with Part 1 and Part 2 - both assigned to the same movie-id
https://www.imdb.com/title/tt1911663/?ref_=fn_al_tt_4
but it would be helpful, if I could “see” which version is part one:)
(hope image upload worked)
… instead of just seeing:
play Version:
5.2 Mbps, 576i
5.3 Mbps, 576i
I’m pretty sure there is a feature request for this that you can add your vote to.
(Sorry, On mobile at the moment so difficult to link)
As for the existing feature suggestion mentioned by Hitsville:
As for your actual issue… If this is 2 sequential parts of the same video instead of different (quality) versions… you might need to review your file naming. Properly named, such stacked files will be displayed as a single item with the duration of all its parts, playing all those parts in sequence.
Example:
Movies   <- the folder linked to your movie library
  Die letzte Spur - Alexandra, 17 Jahre (2011)
    Die letzte Spur - Alexandra, 17 Jahre (2011) - pt1.ext
    Die letzte Spur - Alexandra, 17 Jahre (2011) - pt2.ext
Thx for your hints.
Just voted for the “feature”:slight_smile:
would really be great if implemented.
