Visual bug with Plex on an iPad using Split View
When using the app to view the details of a movie or show, there’s a funny visual bug that can pop up when using Split View on an iPad.
If you have it where Plex is the wider of the two apps, and you open an item, the buttons to mark the item as played, download it, or add it to your watchlist are super squished.
If you readjust the apps to be a 50/50 split, then switch back to the original split, it seems to fix the issue, though the favoriting stars are squished a bit now.
Hopefully this is the proper way to report this because I really don’t know where else to go if not. For reference, this is on an iPad Pro (11-inch) :sweat_smile:
Server Version#: 1.28.2.6151
Player Version#: 8.8
