As the Transmogrify for Plex Chrome extension no longer works with current versions of Plex, I decided to make a visualisation of Plex movie data using Tableau.
Here is a visualisation of a sample data set
You can use this visualisation for your own library, with freely-available software.
Instructions
Get the Tableau workbook and data file:
Go to the Tableau workbook
Click on ‘Download Workbook’
Download the sample data file (‘movies.xlsx’)
Update the data file with your data:
Install the ExportTools Plex plugin
In Plex, go to channels, click on settings for ExportTools and select ‘Level 5’ for ‘Movie Export Level’ - click save
Open the ExportTools channel, click on your movie library to export the data
Open the sample data file (‘movies.xlsx’), delete everything from column D onward and paste in the data from your export file
Type your genres in column A to generate totals (this part handles movies with multiple, custom genres)
Tableau Public:
Doanload and install Tableau Public (free)
Open the workbook in Tableau Public (‘plex movies.twbx’)
Go to ‘Data Source’
Select ‘movies.xlsx’
Go to the ‘Plex data’ tab to visualise your data
