Voddler Plugin
Could someone please provide a voddler log of a successful playback (not a trailer)?
I haven't used this plugin for a very long time, but I tried viewing the free movie "Evil Ed".
Your log from #79:
http://forums.plexapp.com/index.php/topic/26521-voddler-plugin/page-4#entry397287
looks very similiar to mine, it is working for me:
2013-05-18 16:31:40,495 (-4faed000) :  DEBUG (runtime:811) - Found route matching /video/voddler/:/function/playVideo
2013-05-18 16:31:40,495 (-4faed000) :  DEBUG (runtime:143) - Calling function 'playVideo'
2013-05-18 16:31:40,495 (-4faed000) :  INFO (__init__:1415) - Trying to play video with ID: 2756631855405573758
2013-05-18 16:31:40,496 (-4faed000) :  DEBUG (networking:172) - Requesting 'https://api.voddler.com/userapi/vnettoken/1'
2013-05-18 16:31:40,779 (-4faed000) :  INFO (__init__:175) - vnet token:
2013-05-18 16:31:40,780 (-4faed000) :  DEBUG (networking:172) - Requesting 'http://api.voddler.com/vnet/index/login-token/'
2013-05-18 16:31:41,220 (-4faed000) :  INFO (__init__:205) - Setting subtitle to: sv_SE 4
2013-05-18 16:31:41,221 (-4faed000) :  DEBUG (networking:172) - Requesting 'http://api.voddler.com/vnet/settings/'
2013-05-18 16:31:41,293 (-4faed000) :  DEBUG (runtime:911) - Response: [302] Redirect, 0 bytes
What version of the plugin are you using? I downloaded the latest from github:
https://github.com/drohr/plex-voddler-plugin/archive/master.zip
and copied the voddler.bundle to the PMS plugin directory.
It seems like the site configuration is not working for you ...
Very strange.. No more entries in the log after that?
What server are you running? I'm running Client and Server on Windows XP.
Do you pay for your account?
Yes I run latest version I guess:
2013-05-18 17:25:48,905 (eac) :  INFO (core:336) - Starting framework core - Version: 2.3.7, Build: de45ef3 (Tue May  7 17:27:01 UTC 2013)
I tried Evil Ed as well - no luck...
I'm running newest version of PMS(0.9.7.22) with newest version of PMC on OS X. I don't pay for an account.
The version you supplied above is not the version of the plugin, rather the version of the plugin framework?
UPDATE:
Webkit playback will not work on Windows XP:
http://wiki.plexapp.com/index.php/Frequently_Asked_Questions#What_are_the_main_differences_between_the_Plex_Media_Server_platforms.3F
Windows WebKit support requires Vista or Windows 7; Windows XP is, unfortunately, not supported.)
Unfortunately this means that Voddler will not work on your setup!
UPDATE:
Ok, that's too bad. Thanks for the info!
UPDATE:
Hmm - my Plex Media Server.log on the other hand says
May 18, 2013 17:23:38:828 [1064] DEBUG - WebKit supports Flash content
May 18, 2013 17:23:38:828 [1064] DEBUG - WebKit supports Silverlight content
May 18, 2013 17:23:38:828 [1064] INFO - Successfully initialized WebKit
Then when trying to play
May 18, 2013 23:21:33:843 [1064] DEBUG - WebKit successfully loaded http://www.voddler.com/playapi/embedded/1?videoId=2721821284152501569&session=cee81422f883786cd511711ad0eae106&format=html&plex=1&wmode=opaquew&quality=autolow&width=1280&height=720
May 18, 2013 23:21:35:406 [1064] DEBUG - WebKit: 7FF2AE10 Plugin loaded [player.voddler.com/VoddlerPlayer.swf] (8 8 1280 720 player)
May 18, 2013 23:21:35:406 [1064] DEBUG - WebKit: Frame was loaded, processing event.
May 18, 2013 23:21:35:406 [1064] DEBUG - WebKit: Executing Moving to state playing.
Here's my output from Plex Media Server log when trying to play - can you please compare with yours [member='meo']
May 18, 2013 23:21:33:687 [2044] DEBUG - [com.plexapp.plugins.voddler] HTTP reply status 302, with 0 bytes of content.
May 18, 2013 23:21:33:843 [4404] DEBUG - Request: GET /video/:/webkit?url=http%3A%2F%2Fwww.voddler.com%2Fplayapi%2Fembedded%2F1%3FvideoId%3D2721821284152501569%26session%3Dcee81422f883786cd511711ad0eae106%26format%3Dhtml%26plex%3D1%26wmode%3Dopaquew%26quality%3Dautolow%26width%3D1280%26height%3D720&prefix=/video/voddler [127.0.0.1:38308] (3 live)
May 18, 2013 23:21:33:843 [4404] DEBUG -  * url => http://www.voddler.com/playapi/embedded/1?videoId=2721821284152501569&session=cee81422f883786cd511711ad0eae106&format=html&plex=1&wmode=opaquew&quality=autolow&width=1280&height=720
May 18, 2013 23:21:33:843 [4404] DEBUG -  * prefix => /video/voddler
May 18, 2013 23:21:33:843 [4404] DEBUG - WebKit: [voddler.com/playapi/embedded/1?videoId=2721821284152501569&session=cee81422f883786cd511711ad0eae106&format=html&plex=1&wmode=opaquew&quality=autolow&width=1280&height=720]
May 18, 2013 23:21:33:843 [4404] DEBUG - Found corresponding plug-in: C:\Documents and Settings\Owner\Local Settings\Application Data\Plex Media Server\Plug-in Support\Data\com.plexapp.plugins.voddler
May 18, 2013 23:21:33:843 [4404] DEBUG - WebKit: Resetting to state fetch-player.
May 18, 2013 23:21:33:843 [4404] DEBUG - Using C:\Documents and Settings\Owner\Local Settings\Application Data\Plex Media Server\Plug-ins\voddler.bundle\Contents/Site Configurations\voddler.xml with score of 22.
May 18, 2013 23:21:33:843 [4404] DEBUG - WK_BrowseToURL http://www.voddler.com/playapi/embedded/1?videoId=2721821284152501569&session=cee81422f883786cd511711ad0eae106&format=html&plex=1&wmode=opaquew&quality=autolow&width=1280&height=720
May 18, 2013 23:21:33:843 [4404] DEBUG - Setting low latency option for two-way stream.
May 18, 2013 23:21:33:843 [4404] DEBUG - Beginning read from two-way stream.
May 18, 2013 23:21:33:843 [4880] DEBUG - WebKit: Sending line: HELLO
May 18, 2013 23:21:34:437 [4272] DEBUG - Request: GET / [127.0.0.1:38309] (4 live)
May 18, 2013 23:21:34:437 [4272] DEBUG - It took 0.000000 sec to serialize a list with 8 elements.
May 18, 2013 23:21:35:406 [1064] DEBUG - Plugin loaded (application/x-shockwave-flash, http://player.voddler.com/VoddlerPlayer.swf, 7FF2AE10, 8, 8, 1280, 720, player)
May 18, 2013 23:21:36:500 [1960] DEBUG - [com.plexapp.plugins.voddler] HTTP reply status 200, with 0 bytes of content.
Here is a Plex Media Server.log(still playing "Evil Ed"):
May 19, 2013 13:33:09 [0xb0ab2000] DEBUG - Setting low latency option for two-way stream.
May 19, 2013 13:33:09 [0xb0ab2000] DEBUG - Beginning read from two-way stream.
May 19, 2013 13:33:09 [0xb0396000] DEBUG - WebKit: Sending line: HELLO
May 19, 2013 13:33:10 [0xa0896540] DEBUG - WebKit: 0x3393e50 Plugin loaded [player.voddler.com/VoddlerPlayer.swf] (8 8 1280 720 player)
May 19, 2013 13:33:11 [0xa0896540] DEBUG - WebKit: Frame was loaded, processing event.
May 19, 2013 13:33:11 [0xa0896540] DEBUG - WebKit: Executing Moving to state playing.
May 19, 2013 13:33:11 [0xb0103000] DEBUG - Request: GET / [127.0.0.1:49767] (2 live)
May 19, 2013 13:33:11 [0xb0103000] DEBUG - It took 0.000112 sec to serialize a list with 10 elements.
May 19, 2013 13:33:11 [0xa0896540] DEBUG - WebKit: Initializing shared memory 1280 x 720
May 19, 2013 13:33:21 [0xb0103000] DEBUG - Request: GET / [127.0.0.1:49844] (2 live)
May 19, 2013 13:33:21 [0xb0103000] DEBUG - It took 0.000104 sec to serialize a list with 10 elements.
May 19, 2013 13:33:21 [0xb0ab2000] DEBUG - Request: GET / [127.0.0.1:49845] (2 live)
May 19, 2013 13:33:21 [0xb0ab2000] DEBUG - It took 0.000110 sec to serialize a list with 10 elements.
May 19, 2013 13:33:31 [0xb0ab2000] DEBUG - Request: GET / [127.0.0.1:49931] (2 live)
May 19, 2013 13:33:31 [0xb0ab2000] DEBUG - It took 0.000102 sec to serialize a list with 10 elements.
May 19, 2013 13:33:39 [0xb0ab2000] DEBUG - Request: GET /servers [127.0.0.1:50023] (2 live)
May 19, 2013 13:33:39 [0xb0ab2000] DEBUG - It took 0.000032 sec to serialize a list with 1 elements.
May 19, 2013 13:33:39 [0xb0ab2000] DEBUG - Request: GET /library/sections [192.168.0.195:50024] (2 live)
May 19, 2013 13:33:39 [0xb0ab2000] DEBUG - It took 0.002003 sec to serialize a list with 4 elements.
May 19, 2013 13:33:39 [0xb0103000] DEBUG - Request: GET /channels/all [192.168.0.195:50025] (2 live)
May 19, 2013 13:33:39 [0xb0103000] DEBUG - It took 0.000962 sec to serialize a list with 41 elements.
May 19, 2013 13:33:41 [0xb0ab2000] DEBUG - Request: GET / [127.0.0.1:50043] (3 live)
May 19, 2013 13:33:41 [0xb0ab2000] DEBUG - It took 0.000110 sec to serialize a list with 10 elements.
May 19, 2013 13:33:51 [0xb0103000] DEBUG - Request: GET / [127.0.0.1:50135] (2 live)
May 19, 2013 13:33:51 [0xb0103000] DEBUG - It took 0.000115 sec to serialize a list with 10 elements.
May 19, 2013 13:33:51 [0xb0ab2000] DEBUG - Request: GET / [127.0.0.1:50137] (2 live)
May 19, 2013 13:33:51 [0xb0ab2000] DEBUG - It took 0.000103 sec to serialize a list with 10 elements.
May 19, 2013 13:34:01 [0xb0ab2000] DEBUG - Request: GET / [127.0.0.1:50225] (2 live)
May 19, 2013 13:34:01 [0xb0ab2000] DEBUG - It took 0.000129 sec to serialize a list with 10 elements.
May 19, 2013 13:34:10 [0xb0396000] DEBUG - WebKit: Sending line: STOP
May 19, 2013 13:34:10 [0xb0396000] DEBUG - WebKit: Stream closed.
May 19, 2013 13:34:11 [0xb0ab2000] DEBUG - Request: GET / [127.0.0.1:50319] (2 live)
May 19, 2013 13:34:11 [0xb0ab2000] DEBUG - It took 0.000101 sec to serialize a list with 10 elements.
May 19, 2013 13:34:11 [0xb0396000] DEBUG - WebKit: Sending line: STOP
May 19, 2013 13:34:11 [0xb0396000] DEBUG - WebKit: Stream closed.
The difference from yours seems to be:
Also, have a look at this:
http://forums.plexapp.com/index.php/topic/36922-troubleshoot-flash-and-silverlight-plugins/
Ok, thx a lot for your efforts!
I had some progress today. I found out there is a
Plex Media Server -> Settings (Advanced) -> Transcoder -> "Webkit window visible"
When enabled this I got playback - first it say voddlernet needed to be started. After I fixed that I actually got playback. But it doesn't work with the default setting "webkit window off screen". Perhaps this is the XP limitation.
Anyway - if webkit kind of means play it on the server and the pass it on to the client - I won't have much use of this anyway. In XP it seems e.g. Flash/Silverlight has issues to "hardware decode" video on my graphic card. Which means stuttering playback. If I get that through plex as well - there's no point...
