Volume buttons on Android causing play pause issue
Server Version#: up to date 5Nov2021
Player Version#: 3.8
plexamp when playing a song, if you use either of the volume up or volume down it will pause whatever is playing currently. Happens both when in the app UI and also when having it run in the background.
Would need to see logs to see what’s going on. The app will only pause if the system sends that command.
