VP9 HDR fix please
Server Version#:1.43.0.10467
Player Version#:10.30.5.4094
Any chance VP9 HDR support could be fixed to play with proper HDR colours?
Here’s the info about the video (mkv)
Video
Format : VP9
Format profile : 2
Format level : 5.0
HDR format : SMPTE ST 2094 App 4, Version 1
Codec ID : V_VP9
Duration : 3 h 0 min
Bit rate : 21.8 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 0)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.110
Stream size : 27.5 GiB (84%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
The player (Google TV streamer) supports the format. It actually plays the same video in youtube app just fine. The video was downloaded to plex. It plays in proper HDR when transcoding, but washed out when direct play is used…
Any ideas?
Thank you
I just checked today and it seems that Jellyfin doesn’t have that issue…
It direct plays the file with no issues just like youtube on the same device (Google TV streamer)
Plex app on windows, no issues as well…
Plex app for android (mobile) flawless…
So I believe it’s Plex app’s for Android TV problem…
