Server Version#:1.25.1.5286-34f965be8
Player Version#:5.29.1
Hello,
i have site to site vpn between two remote sites.
On the mian site i have the qnapnas running plex server 1.25.1.5286-34f965be8 and an LG TV running 5.28.2 and in the local network all work fine.
I adeed a remote site with an ipsec VPN, site to site VPN on two different 192.168.x.0 /24 subnets and the firewalla llows traffic between subets (i use it to trasnfer files).
VPN looks working fine in terms of performances and stability but the LG tv on the remote site running 5.29.1 cant connect to the server.
The wired thing is that i see traffic going back and forth between the lg tv and the plex server on port 32400 but the TV always says that cant reach the server.
Any Idea?
Best regards
Dear ChuckPa,
many thanks for your answer.
The subnets are 192.168.61.0/24 for the master site and 192.168.65.0/24 for the secondary site.
It would not be possible to use 192.168.62.0/24 on the secondary site where the lg tv is because that subnet is already in use in another secondary site.
Do you have another possible solution or test ?
Best regards
i see… well many devices have static IPs, this is why is time consuming…
But if i have no other choice i will do that.
Just for information i use mikrotik routers for the site to site IPSEC VPN.
i dont know if there is any specific setting for this routers to have a look at…
@vannimb Do you have a different device on the remote site to test if plex itself is working through the VPN and so it is a problem with the LG TV? I also have an issue with my LG Tv where it cannot connect to my server securely, but any other client can do so… The root cause is a missing root certificate…
Dear @Mitzsch you pointed me the right way. i had to disable secure connections on the TV settings and server settings and it all started working.
When i enable secure connections teh TV on the remote site does not manage to connect to the server anylonger.
Any idea why this happens?
Best regards
