How do you label these. The seasons/episodes are not relevant. How about studio information, can plex pull this down for each cartoon?
Warner Bros Bugs Bunny Collections
I am not sure what exactly it is that you are referring to. Because over the years there has been a ton of derivative series and movies based on those original characters.
If you are talking about the classic WB cartoon shorts, you can still have them as part of the Looney Tunes TV show.
https://thetvdb.com/series/looney-tunes
But you’ll have to use the ID number from TheTVDB.com to match it, and then set the Episode Ordering to TheTVDB (Aired) as well.
You can also put them into a “Movies” type of library, but then you’ll have to look up each single short and adapt its title and release year to ensure a proper match. I also doubt that you will find all shorts as a movie.
