I get this warning message in my console every 30 seconds. Did a reinstall, not from scratch though but did not help. Thanks in advance
Jan 02, 2024 11:32:37.305 [17840] Debug — [NSB/SSDP] Parsing SSDP schema for http://192.168.0.1:45514/agent.xml
Jan 02, 2024 11:32:37.310 [260] Warning — [HttpClient/HCl#146] HTTP error requesting GET http://192.168.0.1:45514/agent.xml (56, Failure when receiving data from the peer) (Recv failure: Connection was reset)
Jan 02, 2024 11:33:07.319 [17840] Debug — [NSB/SSDP] Parsing SSDP schema for http://192.168.0.1:45514/agent.xml
Jan 02, 2024 11:33:07.322 [260] Warning — [HttpClient/HCl#147] HTTP error requesting GET http://192.168.0.1:45514/agent.xml (56, Failure when receiving data from the peer) (Recv failure: Connection was reset)
I was doing a packet capture on my network trying to troubleshoot something else and saw a bunch of random packets going to my broadcast address for the network it was on. Did a bit of research on the packet and found that they use SSDP for device discovery. Figured out which setting it was related to and disabled it. Went into settings > network and disabled “local device discovery (GDM)” and then the broadcast packets seemed to cease. It’s probably something similar if I had to guess. The setting is for discovering other Plex media servers on the network, which for most people doesn’t apply, so it’s fine to disable this setting.
