No longer possible to add movies to my watchlist
Server Version#: Version 1.41.2.9200
Player Version#: Version 4.142.1
The button to add movies to the watchlist disappeared. There’s no menu option neither, so now it’s impossible to add new movies to the watchlist.
I read online and the only solution is to change the agent to the Plex Movie agent, and then refresh the metadata. However, I’m already using the Plex Movie agent.
The watchlist worked perfectly before, only noticed the bug today but never changed the agent nor anything else affecting this function, at least nothing that I’m aware of.
Server DEBUG logs please ?
There might be a DB issue.
Server Version#: 1.41.3.9232
Player Version#: 4.142.1
I have the same issue when using Plex from Chrome browser. I notice I can still have button available on Android phone App though. The last update seemed to create this problem. I am running Plex on a windows server.
@MiniMe
I request the same… Server DEBUG logs please ?
:slight_smile:
@MiniMe @Doctor_Dri
Please try the following:
  1. Edit the section settings and disable “Adult Content”
  2. Save
  3. Refresh the metadata
  4. Now add movies
If this is an Adult Content issue, I will augment by sharing that these items cannot be added to watchlists.
I am suggesting this because of reports (discrepancies) between Plex/Web and the mobile apps (which is being resolved)
@MiniMe
After changing the setting, did you also refresh the metadata ?
( Normally, just changing the setting has no impact on existing )
I am asking here because we’re tracking a bug which strangely manifests this way with the adult option. lol
You can also check / cross-check by using the hosted app (https://app.plex.tv) to see what difference(s) you see there.
I started a scan and nothing changed. Refreshed the web page itself and the icon appeared.
I did my TV library first. Movies still had no icon until I changed setting, scanned and refreshed browser.
Using app.plex.tv in Chrome is only way I use Plex on laptop.
So the status of the checkbox impacts whether or not the icon appears ?
Exactly. I check the “include adult content” box under advanced in edit library settings and refresh browser and icon disappears. I uncheck the box and refresh browser and watchlist icon is back. Again, using app.plex.tv in chrome. Thanks again for the help !!!
Thank you for your help too !!!
Engineering will just LOVE this one
:joy:
THANK YOU!!! Disabling “adult content” did work!! Specifically, editing the library and under Advanced I unchecked the “include adult content” box and refreshed chrome browser. The icon is back. I do not have any adult content in my libraries though.
Unchecking the option “Include adult content” and then refreshing the metadata and the browser page, allowed to add movies to the watchlist again. Thanks.
That being said, it would be good to be able to add movies to the watchlist even if libraries allow adult content, because the setting is also blocking the addition of regular, for-all-audiences, movies.
It seems odd to have made this functionality disappear. Is Plex not able to determine if something is adult content and only on that item disable the watchlist option? Having to disable a setting and refresh all metadata just to get back the watchlist functionality is weird. I guess I checked the adult setting thinking it was needed for R rated movies.
I just spend more than a hour to troubleshot the Watchlist bug by accidently finding this thread here and tried successfully the workaround.
It’s a bug combined w/ a really bad usability and an intransparent communication.
Please try to fix this bug as soon as possible.
