Watchlist maximum?
Is there a maximum number of items that can be added to the ‘Watchlist’? I was adding movies and then subsequent movies did not have the option to add. I have check and I currently have 48 in list.
not that I am aware of. If you remove one that is on it can you then add one that didn’t have the option. are you sure the movies that did not have option are matched with Plex Movie agent?
