Watchlist Suddenfly Showing An Exclamation Point and Not Accessible
Hello. All the sudden and while everything was working fine, I get an exclamation point on “Watchlist” and it is no longer accessible. All other sections of the interface (my library, Movies & Shows, TV…) work fine… Any clue? Thanks
Having the same problem. Nothing I can figure out, including logging out and back in, fixes it.
Same problem here. It seems to be fine via Web but on my nvidia shield, it’s exclamation mark. No idea why and just started a few days ago as well.
Same issue here.
Same problem here with Watchlist and Discover tabs. No way to fix it ?
I was able to fix the issue by updating Flex to the latest version
Both the Watchlist and Discover are online features. They require a working internet connection to plex.tv servers.
If both are showing an exclamation mark, then a connection issue (for instance a general internet outage, or a firewall blocking too much) is the most likely reason.
If only one of them is showing the exclamation mark, then I’d definitely check the web browser for installed browser add-ins. Definitely compare the behaviour with the Plex for Desktop app.
If several app types show the issues, then it might be either a connection issue or an outage on plex.tv
Check the forums and/or https://status.plex.tv/
