Web client cannot connect to PMS. Android app and Rasplex connect fine.
I’m running 1.0.3 as an unRaid docker.
I’ve been experimenting with user accounts, and in troubleshooting another issue where RasPlex wouldn’t switch users I experimented with allowing fallback to secure connections. That thread is here.
I’ve now managed to lock myself out of server settings.
I can still use plex fine from the Android app, and cast to Chromecast, and from my main user on the Rasplex.
However when point the web browser at http://[plex LAN ip]:32400/web/index.html, I am prompted to select user. If I select my main user I am prompted to enter a PIN, and then I get to the main Plex screen.
My server name has a red triangle next to it and says “unavailable”
How I can reconnect to my server? Thanks!
Anyone got any pointers? Thanks
Anyone ?
I am having the same issues since the lastest update. I have to use internet explorer to connect. Both Chrome and Firefox fail to connect.
also have problems with connection https friends of my also
This is a Plex issue. Either with their own network or with the service that hosts their SSL certs. Many of my remote users can not access my server any longer using secure connections since 1-2 days ago.
I’m having the same issue since the last update. I’ll try using IE as JDKincaid, but this sucks.
