Server Version#: 1.15.2.793
Player Version#: 3.91.0
Recently I’ve noticed that web player will never succeed in playing LiveTV. Either it just shows: “Could not tune channel. Please check your tuner or antenna.” directly or it buffers for an eternity. If I’m lucky I can rewind 10 seconds and it might start playing or at least show a frame.
I’ve noticed the same behaviour using the Experimental Player on the standalone beta (iOS + AppleTV) but I’ve attributed that to being beta and the fact that the experimental player is not up to the task just yet (standard player works fine in this regard on AppleTV and iOS).
Anyone having similar issues? I honestly expected to find similar posts but I couldn’t really.
Further research showed that the stream indeed does start but it takes about 30 seconds. It then plays for a few seconds, stops a few seconds and then continues to play again. On other clients it is more or less instant.
Also regarding the issues on iOS+AppleTV: switching back to native standard player and every channel works. So the experimental player is a bit wonky but that is expected at this point anyway.
