Weird playback issue - Hisense U7 VIDAA
Server Version#: 1.30.1.6592
App name: Plex for VIDAA
Client version: 5.52.3
Platform Version: V0000.06.10M.M0901
I bought a new Hisense U7 TV yesterday, running VIDAA OS, and have just discovered a weird playback issue when using plex.
If I try to restart, or watch something that I haven’t watched before, the playback crashes after a few seconds.
If start something that is part way through, it plays back without issue.
If I start the media and fast forward slightly before it crashes, the playback is fine, I can then even rewind to 00:00 and it plays back without issue.
I can start media from a friends server fine, all his content is 720 max resolution. My media is1080p/4k.
I have tried to disable direct play, forcing it to use direct stream/transcode and it just buffers constantly.
Also, probably unrelated, but album art, and background images won’t show if prefer insecure connection is selected. I have tried setting DNS to 8.8.8.8.
Playback is fine on other devices, both local and remote.
Does anyone have any ideas how to fix this
It’s driving me nuts.
Same problem with a Devant TV. Info from the logs:
Jan 09, 2023 09:26:39.795 [12000] INFO - Plex Media Server v1.30.1.6497-5fc2e0894 - Microsoft PC x64 - build: windows-x86 windows - GMT 08:00
Jan 11, 2023 09:50:53.351 [7472] INFO - [Req#9e66] [Plex for VIDAA] [qtxom:redacted] Navigated to screen: VisualMediaPlaybackScreen
Jan 11, 2023 09:50:54.148 [7472] ERROR - [Req#9e74] Unable to find client profile for device; platform=vidaa, platformVersion=V0000.01.00K.M0929, device=VIDDA V0000.01.00K.M0929, model=55A53FSV
Jan 11, 2023 09:50:58.478 [7472] INFO - [Req#9eba] [Plex for VIDAA] [qtxom:redacted] [PlaybackMetrics] Attaching playback metrics to PlayerController
Jan 11, 2023 09:50:58.478 [7472] INFO - [Req#9eba] [Plex for VIDAA] [qtxom:redacted] [ServerConnectionTestManager] Stopped
Jan 11, 2023 09:50:58.478 [7472] INFO - [Req#9eba] [Plex for VIDAA] [qtxom:redacted] [MDE] Application decision, directPlay: true, directStreamVideo: true, directStreamAudio: true
Jan 11, 2023 09:50:58.478 [7472] INFO - [Req#9eba] [Plex for VIDAA] [qtxom:redacted] videoStream: {
“id”: 17581,
“streamType”: 1,
“default”: true,
“codec”: “h264”,
“index”: 0,
“bitrate”: 659,
“bitDepth”: 8,
“chromaLocation”: “left”,
“chromaSubsampling”: “4:2:0”,
“codedHeight”: 720,
“codedWidth”: 1280,
“colorRange”: “tv”,
“frameRate”: 23.976,
“hasScalingMatrix”: false,
“height”: 720,
“level”: 31,
“profile”: “high”,
“refFrames”: 4,
“scanType”: “progressive”,
“title”: “redacted”,
“width”: 1280,
“displayTitle”: “720p (H.264)”,
“extendedDisplayTitle”: “redacted (720p H.264)”
Jan 11, 2023 09:50:58.478 [7472] INFO - [Req#9eba] [Plex for VIDAA] [qtxom:redacted] audioStream: {
“id”: 17582,
“streamType”: 2,
“selected”: true,
“default”: true,
“codec”: “aac”,
“index”: 1,
“channels”: 2,
“language”: “English”,
“languageTag”: “en”,
“languageCode”: “eng”,
“audioChannelLayout”: “stereo”,
“profile”: “lc”,
“samplingRate”: 48000,
“displayTitle”: “English (AAC Stereo)”,
“extendedDisplayTitle”: “redacted (English AAC Stereo)”
Jan 11, 2023 09:50:58.479 [7472] INFO - [Req#9eba] [Plex for VIDAA] [qtxom:redacted] subtitleStream: {
“id”: 17583,
“streamType”: 3,
“selected”: true,
“default”: true,
“codec”: “srt”,
“index”: 2,
“displayTitle”: “English (SRT)”,
“extendedDisplayTitle”: “redacted (English SRT)”
Jan 11, 2023 09:50:58.479 [7472] INFO - [Req#9eba] [Plex for VIDAA] [qtxom:redacted] [MDE] Server decision, directPlay: true, directStreamVideo: true, directStreamAudio: true
Jan 11, 2023 09:50:58.479 [7472] INFO - [Req#9eba] [Plex for VIDAA] [qtxom:redacted] reason: Direct play OK.
Jan 11, 2023 09:50:58.479 [7472] INFO - [Req#9eba] [Plex for VIDAA] [qtxom:redacted] [PlaybackSessionController] playback state changed to: buffering
Jan 11, 2023 09:50:58.479 [7472] INFO - [Req#9eba] [Plex for VIDAA] [qtxom:redacted] [PlaybackSessionController] playback state changed to: playing
Jan 11, 2023 09:50:58.479 [7472] INFO - [Req#9eba] [Plex for VIDAA] [qtxom:redacted] [Subtitles: Engine] Created Subtitles Engine
Jan 11, 2023 09:50:58.479 [7472] INFO - [Req#9eba] [Plex for VIDAA] [qtxom:redacted] [Subtitles: Controller] Initializing controller
Jan 11, 2023 09:50:58.479 [7472] INFO - [Req#9eba] [Plex for VIDAA] [qtxom:redacted] [Subtitles: Connection] Received new connection request at offset 0
Jan 11, 2023 09:50:58.479 [7472] INFO - [Req#9eba] [Plex for VIDAA] [qtxom:redacted] [Subtitles: Connection] Opening connection at offset 0
Jan 11, 2023 09:51:05.532 [7472] INFO - [Req#ab02] [Plex for VIDAA] [qtxom:redacted] [Subtitles: XHR] All data received (Total 38843 bytes). Connection closed.
Jan 11, 2023 09:51:05.532 [7472] INFO - [Req#ab02] [Plex for VIDAA] [qtxom:redacted] [PlaybackSessionController] playback state changed to: stopped
Jan 11, 2023 09:51:05.864 [7472] WARN - [Req#ab06] QueryParser: Invalid field ‘sectionID’ found, ignoring.
Jan 11, 2023 09:51:05.864 [7472] WARN - [Req#ab06] QueryParser: Invalid field ‘contentDirectoryID’ found, ignoring.
Jan 11, 2023 09:51:05.864 [7472] WARN - [Req#ab06] QueryParser: Invalid field ‘pinnedContentDirectoryID’ found, ignoring.
Jan 11, 2023 09:51:10.541 [8776] INFO - [Req#ab08] [Plex for VIDAA] [qtxom:redacted] Navigating to screen: PostPlayScreen
I found a similar playback issue on my TV - appears to happen only with HDR content - where video stops playing after about 2 or 3 seconds. Non-HDR content appears to play without a hitch.
Only workaround I found (and as you mentioned) was as soon as the video starts playing, skip forward (30s) - then skip back 3 times (10s * 3) to go back to the start - then movie playing fine from the beginning.
