What drive does Plex use first?
I have a SSD and spinning disk attached to my Plex server. The SSD has 4K files, while the hdd has both 4K and 1080p. What priority will Plex use? I need it to play the file on the SSD 1st.
Which SSD is your root partition?
PMS is installed, by default, on /var/lib/plexmediaserver
What you’re asking isn’t really clear. would you elaborate please?
Why should a SSD play before a HD?
I have 2 folders setup in the Plex Meda Player GUI which has the same videos on. I want to know where it plays from?
then when naming them give them slightly different names. like ssd movies, hdd movies. i mean it’s really not complicated since you have the option of naming a library while creating it.
