Curious as to what formats are not currently supported playing natively on the current plex app in xbox one.
Is it just dts for audio and currently mkv for video? (Although I hear that mkv is supported by the xbox one ulna player but not by third party apps).
Is it likely that microsoft will make mkv available for plex?
Also on dts I vaguely remember in the past that this wasn't available on other media players due to a required license fee? Is this likely the case with the xbox one and if so I presume that means we will never get support?
I'd like to see some proof, since you would be the only one that can. Are you sure it's not "direct stream" instead of "direct play"? direct stream means it's being remuxed to a different container (mp4 likely).
