What is in "AppData\Local\Temp" Directory?
Server Version#:Most recent on Windows 2016
What is in the above folder that Plex needs? It is over 30GB, and PMS is the only thing running under this account.
TIA
jandk
it is used for various things but guessing it might be Credit Detection not cleaning up after itself properly. There is a fix for that in latest beta 1.31.3.6819
FIXES:
  • (CreditsDetection) Improve temporary directory clean-up (#14169)
I just took a peek. There were 500k thumbnails. Thousands were of a “5 hour energy” ad.
This brought my server to its knees. Ouch.
I’m deleting everything. I’ll check in a day or two and see if it builds up again.
Very odd.
In addition to the credit detection cleanup fix:
Why is my Plex Media Server directory so large?
[HowTo] An extended guide on how to move the Plex data folder on Windows
Thanks FordGuy. That directory is only 10gb, which I can handle. Overnight, Plex wrote 3gb of 40kb thumbnails into its temp directory.
What a charming little glitch. I guess I’ll install the beta.
