What is this HTPC Widget called & how to modify the volume level
Server Version#: Latest
Player Version#: HTPC latest.
Hey Guys, my searching didn’t yield a result (could be a “bloke look”) … this widget that appears when pausing, what is it called? It shows volume level of 80 but for life of me can’t find how to modify that and doesn’t seem to correlate to any actual volume levels in play?
Cheers
That isn’t part of HTPC. I think that is the media controls for windows 10.
BigWheel is right, you’re using the Windows media keys on the keyboard
To pause your video hit the space bar
To adjust the volume inside Plex use these keys
1BNgG
Ahh! thanks guys, didn’t know such a thing was in existence, recent OS updates must have snuck it in somehow. Might look to disabling the windows 10 media controls to stick with the HTPC controls.
