Since a couple of days Plex Connect is not working anymore, the only message after a while is "Trailers not avaleble"
I'm running Plex server and Plex connect on a windows 7 PC.
Somebody an idea how to solve the problem?
Most likely this > http://langui.sh/2013/08/27/appletv-ssl-plexconnect/, if you haven't done it
There are also numerous hints all over this forum.
I really hope to see the dust settling in the near future... :-D
Tried tis, not found....
Take the main page...
Edit: Actually the link has just a wrong DOT at the end.
Edit: Ok, it's a ","
Edit: Correct link - http://langui.sh/2013/08/27/appletv-ssl-plexconnect/
I hope so, I've tried the things I can find for Windows but nothing is working, Trailers still can't contact the Plex Server. Back to the old days, Plex player on the iPad and send it to the Apple TV. This also give's a problem if your DNS server still point to the Plex Connect server, it play's fot one time then you have to reset the wifi of the iPad or iPhone.
Also back to the standard DNS IP number.
I'm running Windows...
So? There is a Windows section as well.
you NEED to do this to get your aTV to work with plex since apple updated the channels.
For Windows it says to use the iPhone Configuration Utility.
OK, found it.I did everything as discribed and the result is a working PlexConnect again!!
If you are using the iPhone configurating utility you have to fill in something by Organization alse you can't upload the file to the ATV.
Thanks for the help
... congratulations!
:-D
Thanks for the help
I didnt have to do this?, could be the version of config util you are using, i wasnt using the latest.
Maybe thats the fact. I downloaded the latest version of the iPhone configuration utility, with the Mac configuration utility it's not necessary.
