Help/Advice Please
Hi all some help required please to the 'Trailers is Unavailable. Try again Later' issue.
ATV3 5.2.1(6025)
ATV DNS 192.168.1.90
PC Running Windows 7 Ultimate
PC IP 192.168.1.90
PMS downloaded yesterday on 192.168.1.90
Plex Connect downloaded yesterday
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\Dan>C:\Users\Dan\Desktop\PlexConnect-0.1-iOS-pre5.1\PlexConnect-0.1-iOS
-pre5.1\Settings.pyc
09:37:33 __main__: init class CSettings
09:37:33 __main__: load settings
09:37:33 __main__: getsetting enable_plexgdm=True
True
09:37:33 __main__: getsetting enable_dnsserver=True
True
09:37:33 __main__: save settings
-pre5.1\PlexConnect.pyc
09:37:42 PlexConnect: started: 09:37:42
09:37:42 PlexConnect: ***
09:37:42 PlexConnect: PlexConnect
09:37:42 PlexConnect: Press ENTER to shut down.
09:37:42 PlexConnect: IP_self: 192.168.1.90
09:37:42 PlexGDM: ***
09:37:42 PlexGDM: looking up Plex Media Server
09:37:43 PlexGDM: servers discovered: 1
09:37:43 PlexConnect: PMS: 192.168.1.90:32400
09:37:44 DNSServer: started: 09:37:44
09:37:44 DNSServer: ***
09:37:44 DNSServer: Starting up.
09:37:44 DNSServer: intercept trailers.apple.com: 192.168.1.90
09:37:44 DNSServer: forward other to higher level DNS: 8.8.8.8
09:37:44 WebServer: started: 09:37:44
09:37:44 WebServer: ***
09:37:44 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
09:38:17 DNSServer: DNS request received!
09:38:17 DNSServer: Source: ('192.168.1.96', 50624)
09:38:17 DNSServer: Domain: ax.init.itunes.apple.com
09:38:17 DNSServer: ***forward request
09:38:17 DNSServer: -> DNS response from higher level
09:38:18 DNSServer: DNS request received!
09:38:18 DNSServer: Source: ('192.168.1.96', 61476)
09:38:18 DNSServer: Domain: p32-buy.itunes.apple.com
09:38:18 DNSServer: ***forward request
09:38:18 DNSServer: -> DNS response from higher level
09:38:20 DNSServer: DNS request received!
09:38:20 DNSServer: Source: ('192.168.1.96', 49862)
09:38:20 DNSServer: Domain: trailers.apple.com
09:38:20 DNSServer: ***intercept request
09:38:20 DNSServer: -> DNS response: 192.168.1.90
Any ideas appreciated. I think I followed all the steps?
As usual: OLD software does NOT support NEW features.
You got to update PlexConnect.
To be clear you’re using a branched code. Make sure you select the Master when cloning to desktop from GitHub.
Additional advice: create a concise yet descriptive title for the topic.
Thanks guys, updated to latest version of Plex Connect and still same error?
C:\Users\Dan>C:\Users\Dan\Desktop\PlexConnect-master
'C:\Users\Dan\Desktop\PlexConnect-master' is not recognized as an internal or ex
ternal command,
operable program or batch file.
C:\Users\Dan>C:\Users\Dan\Desktop\PlexConnect-master\PlexConnect.py
10:33:39 PlexConnect: ***
10:33:39 PlexConnect: PlexConnect
10:33:39 PlexConnect: Press CTRL-C to shut down.
10:33:39 Settings: add section PlexConnect
10:33:39 Settings: add option logpath=.
10:33:39 Settings: add option enable_dnsserver=True
10:33:39 Settings: add option ip_webserver=0.0.0.0
10:33:39 Settings: add option prevent_atv_update=True
10:33:39 Settings: add option enable_plexconnect_autodetect=True
10:33:39 Settings: add option port_pms=32400
10:33:39 Settings: add option port_webserver=80
10:33:39 Settings: add option ip_plexconnect=0.0.0.0
10:33:39 Settings: add option certfile=./assets/certificates/trailers.pem
10:33:39 Settings: add option ip_dnsmaster=8.8.8.8
10:33:39 Settings: add option loglevel=Normal
10:33:39 Settings: add option ip_pms=192.168.178.10
10:33:39 Settings: add option enable_plexgdm=True
10:33:40 Settings: add option port_ssl=443
10:33:40 PlexConnect: started: 10:33:40
10:33:40 PlexConnect: IP_self: 192.168.1.90
10:33:40 DNSServer: started: 10:33:40
10:33:40 DNSServer: ***
10:33:40 DNSServer: Starting up.
10:33:40 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.
168.1.90
10:33:40 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld
.apple.com.edgesuite.net'] => 127.0.0.1
10:33:40 DNSServer: forward other to higher level DNS: 8.8.8.8
10:33:40 WebServer: started: 10:33:40
10:33:40 WebServer: ***
10:33:40 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
10:33:40 WebServer: WebServer: Serving HTTPS on 0.0.0.0 port 443.
10:33:40 PlexGDM: ***
10:33:40 PlexGDM: looking up Plex Media Server
10:33:41 PlexGDM: servers discovered: 1
10:33:41 XMLConverter: PlexGDM - PMS: 192.168.1.90:32400
10:34:04 DNSServer: DNS request received!
10:34:04 DNSServer: Source: ('192.168.1.96', 64938)
10:34:04 DNSServer: Domain: ax.init-cdn.itunes.apple.com.akadns.net
10:34:04 DNSServer: ***forward request
10:34:04 DNSServer: -> DNS response from higher level
10:34:04 DNSServer: Source: ('192.168.1.96', 63528)
10:34:04 DNSServer: Domain: p32-buy.itunes.apple.com.akadns.net
10:34:06 DNSServer: DNS request received!
10:34:06 DNSServer: Source: ('192.168.1.96', 64119)
10:34:06 DNSServer: Domain: trailers.apple.com
10:34:06 DNSServer: ***intercept request
10:34:06 DNSServer: -> DNS response: 192.168.1.90
10:34:08 DNSServer: DNS request received!
10:34:08 DNSServer: Source: ('192.168.1.96', 52858)
10:34:08 DNSServer: Domain: itunes-cdn.apple.com.akadns.net
10:34:08 DNSServer: ***forward request
10:34:08 DNSServer: -> DNS response from higher level
10:34:25 DNSServer: DNS request received!
10:34:25 DNSServer: Source: ('192.168.1.96', 53533)
10:34:25 DNSServer: Domain: a771.da1.akamai.net
10:34:25 DNSServer: ***forward request
10:34:25 DNSServer: -> DNS response from higher level
10:34:44 DNSServer: DNS request received!
10:34:44 DNSServer: Source: ('192.168.1.96', 54504)
10:34:44 DNSServer: Domain: api-global.netflix.com
10:34:44 DNSServer: ***forward request
10:34:44 DNSServer: -> DNS response from higher level
10:34:44 DNSServer: Source: ('192.168.1.96', 58054)
10:34:44 DNSServer: Domain: a771.da1.akamai.net
10:34:44 DNSServer: Source: ('192.168.1.96', 55992)
10:34:44 DNSServer: Domain: securemetrics.apple.com
10:34:45 DNSServer: DNS request received!
10:34:45 DNSServer: Source: ('192.168.1.96', 57490)
10:34:45 DNSServer: Domain: api-eu.netflix.com
10:34:45 DNSServer: ***forward request
10:34:45 DNSServer: -> DNS response from higher level
10:34:45 DNSServer: Source: ('192.168.1.96', 62577)
10:34:45 DNSServer: Domain: secure.netflix.com
10:34:45 DNSServer: Source: ('192.168.1.96', 53313)
10:34:45 DNSServer: Domain: nmtracking.netflix.com
10:34:48 DNSServer: DNS request received!
10:34:48 DNSServer: Source: ('192.168.1.96', 55908)
10:34:48 DNSServer: Domain: cdn1.nflximg.net
10:34:48 DNSServer: ***forward request
10:34:48 DNSServer: -> DNS response from higher level
10:34:48 DNSServer: Source: ('192.168.1.96', 53283)
10:34:48 DNSServer: Domain: cdn0.nflximg.net
10:35:00 DNSServer: DNS request received!
10:35:00 DNSServer: Source: ('192.168.1.96', 58533)
10:35:00 DNSServer: Domain: a1.mzstatic.com
10:35:00 DNSServer: ***forward request
10:35:00 DNSServer: -> DNS response from higher level
Have you done the required certificate steps due to the apple change from http to https?
http://langui.sh/2013/08/27/appletv-ssl-plexconnect/
I had not done. Now i am trying to complete the first step of this process and I have the following issue...
C:\Users\Dan>openssl req -new -nodes -newkey rsa:2048 -out ~/Desktop/trailers.pe
m -keyout ~/Desktop/trailers.key -x509 -days 7300 -subj "/C=US/CN=trailers.apple
.com"
'openssl' is not recognized as an internal or external command,
Any ideas? The script is copied from the link you provided.
Ive also just noticed that the iPhone Configuration utility does not seem to have 'trailers.cer' in the credentials area?
... on Win, you need to install it.
