Tried everything and still ¨Trailers not available right now¨ please help
Hello everyone! I would appreciate any help on this I am very frustrated, I have the same issue as Mr.1inch Iread his post and also tried everything proposed there and still I have not been able to get it working.
§  A detailed description of the issue : At first it didn’t work, then I was busy for a few days and didn’t have to time for it, when I got back to try and set it, I do not know what I did but it decided to work, it did so for a few days and then again out the blue it decided that our relationship was over and took off. I followed the guide every step of the way, and everything should be working as of now. However, when I try to load the 'trailers' app on my APV it says "trailers not available right now".  I did manage to load the cert via Apple configurator. And it shows just fine on the ATV3
§  ATV3, Firmware: 7.0.2 (6915) ATV3 and firmware version 8.1.1 (12B435)
§  The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.1.35
§  The local IP address of the device that PlexConnect is installed on: 192.168.1.35
§  The device and operating system (including version number) that PlexConnect is installed on: Application folder on a Mac pro 2009 OS X 10.10 Yosemite
§  The device and operating system (including version number) that the Plex media server (PMS) is installed on: Application folder on a Mac pro 2009 OS X 10.10 Yosemite
§  The Plex media server (PMS) version number you are running : 0.9.11.7
§  The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.1.35
§  The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any non-standard setup e.g. Plexify or a fork. Github, downloaded on 5-1-15
§  The contents of your 'Settings.cfg' file (this is created at first clean shutdown of PlexConnect, using CTR+c): [PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.178.10
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
loglevel = Normal
logpath = .
§  PlexConnect.log: http://pastebin.com/7XNDmNEC
So I finally managed to get it working again. What I did is:
Created new certificates
Ran the sudo on Terminal for plexconnect
Accesed my ATV3 erased the old profiles and tried to load via http://trailers.apple.com/trailers.cer
AND PUFFF!!! Out of the blue she is back again, didn't apologize, said nothing about why she left, but we are back together in a happy relationship, lets see how long it lasts.
... Out of the blue she is back again, didn't apologize, said nothing about why she left, but we are back together in a happy relationship, lets see how long it lasts.
Here she comes in the beauty of the night... PlexConnect is a boy, though :-)
Last time I checked it was a sheep and a dinosaur  :huh:
