Server Version#: 1.22.1.4275
Player Version#: 4.54.5
In list view, if you add some of the extra available columns, it will add the headers but not the actual data that should be in the columns. So the alignment just goes way off.
I believe that’s a known issue – at least I’ve seen posts about it before.
Is this being tracked as an actual bug fix? Seems like something that shouldn’t be too hard to resolve. I.E. If there are 6 columns selected, show all 6 columns.
One odd tidbit I’ve noticed is if you navigate into a folder that has both media files and another folder, all columns appear and align correctly. The missing columns seem to occur when you go into the deepest folder in the current hierarchy, and only media files are in it.
Mostly it’s a fixed bug if you’re using the latest version of Plex Web (https://app.plex.tv/desktop) or Plex for Mac/Windows (v1.31+). The “local” version bundled with your server will still have to wait a little longer.
