When requesting audio transcode, WebOS app buffers until timeout
Server Version: 5.2.0
Player Version: 5.6.1
TV: LG 75UN6970PUD
Video transcoding is disabled. Direct Play and Direct Stream are both enabled.
This TV is incompatible with DTS, so I disabled it in my Plex app settings.
However, when I play a movie, instead of transcoding the audio stream, it just buffers for a while and then times out.
Here’s a relevant snip from the log:
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] Navigated to screen: VisualMediaPlaybackScreen
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] WARN - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] _onOnPlayPauseInvokedChanged is not defined for @autoCallback property: onPlayPauseInvoked
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] [MDE] Application decision, directPlay: false, directStreamVideo: true, directStreamAudio: false
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     Cannot direct play with protocol: http, codec: dca. Reason: Codec dca is excluded per setting DTS: false
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     Cannot direct stream with protocol: hls, codec: dca. Reason: Codec dca is excluded per setting DTS: false
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]   videoStream: {
  "id": 750,
  "streamType": 1,
  "codec": "hevc",
  "index": 0,
  "bitrate": 64733,
  "language": "English",
  "languageCode": "eng",
  "bitDepth": 10,
  "chromaSubsampling": "4:2:0",
  "codedHeight": 2160,
  "codedWidth": 3840,
  "colorPrimaries": "bt2020",
  "colorRange": "tv",
  "colorSpace": "bt2020nc",
  "colorTrc": "smpte2084",
  "frameRate": 23.976,
  "height": 2160,
  "level": 153,
  "profile": "main 10",
  "refFrames": 1,
  "width": 3840,
  "displayTitle": "4K (HEVC Main 10 HDR)",
  "extendedDisplayTitle": "4K (HEVC Main 10 HDR)"
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]   audioStream: {
  "id": 752,
  "streamType": 2,
  "selected": true,
  "codec": "dca",
  "index": 2,
  "channels": 6,
  "bitrate": 1536,
  "audioChannelLayout": "5.1(side)",
  "bitDepth": 24,
  "profile": "dts",
  "samplingRate": 48000,
  "title": "Surround 5.1",
  "displayTitle": "English (DTS 5.1)",
  "extendedDisplayTitle": "Surround 5.1 (English DTS)"
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]   subtitleStream: none
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] [MDE] Server decision, directPlay: false, directStreamVideo: true, directStreamAudio: false
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]   reason: App cannot direct play this item. Direct play is disabled.
  "bitrate": "64733",
  "codec": "hevc",
  "extendedDisplayTitle": "4K (HEVC Main 10 HDR)",
  "frameRate": "23.975999999999999",
  "height": "2160",
  "id": "750",
  "streamType": 1,
  "width": "3840",
  "decision": "copy",
  "location": "segments-av"
  "bitrate": "774",
  "bitrateMode": "cbr",
  "channels": 6,
  "codec": "aac",
  "extendedDisplayTitle": "Surround 5.1 (English DTS)",
  "id": "752",
  "selected": "1",
  "streamType": 2,
  "decision": "transcode",
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]   augmentations with profile: Generic
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-transcode-target streaming videoProfile hls mpegts h264,hevc,mpeg2video,mpeg4 aac,ac3,eac3,mp2,mp3
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-limitation videoAudioCodec mp2 upperBound audio.bitrate 350
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-limitation videoAudioCodec mp3 upperBound audio.bitrate 350
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-limitation videoCodec h264 upperBound video.level 51
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-limitation streaming videoTranscodeTarget h264 hls upperBound video.bitDepth 8
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-limitation streaming videoTranscodeTarget h264 hls upperBound video.width 3840
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-limitation streaming videoTranscodeTarget h264 hls upperBound video.height 2160
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-limitation streaming videoTranscodeTarget hevc hls upperBound video.bitDepth 10
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-limitation streaming videoTranscodeTarget hevc hls upperBound video.width 3840
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-limitation streaming videoTranscodeTarget hevc hls upperBound video.height 2160
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-limitation streaming videoTranscodeTarget mpeg2video hls upperBound video.bitDepth 8
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-limitation streaming videoTranscodeTarget mpeg2video hls upperBound video.width 1920
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-limitation streaming videoTranscodeTarget mpeg2video hls upperBound video.height 1080
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-limitation streaming videoTranscodeTarget mpeg4 hls upperBound video.bitDepth 8
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-limitation streaming videoTranscodeTarget mpeg4 hls upperBound video.width 1920
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu]     add-limitation streaming videoTranscodeTarget mpeg4 hls upperBound video.height 1080
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] DEBUG - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] [PlaybackSessionController] Setting up player for playback
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] DEBUG - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] [PlaybackSessionController] Creating player
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] DEBUG - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] [PlaybackSessionController] Created player
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] DEBUG - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] [PlaybackSessionController] Set player
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] [SubtitleConnectionManager] Subtitle connection ignored. App is not rendering subtitles.
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] DEBUG - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] [PlaybackSessionController] Checking for Ad
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] DEBUG - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] [PlaybackSessionController] Finished checking for Ad
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] [PlaybackSessionController] playback state changed to: buffering
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] DEBUG - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] [PlaybackSessionController] Opening playback
Jan 04, 2021 23:12:57.814 [0x7f5870ff9700] INFO - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] [PlaybackSessionController] playback state changed to: playing
Jan 04, 2021 23:12:57.815 [0x7f58ae94c700] DEBUG - Completed: [192.168.86.48:44252] 200 POST /log (11 live) GZIP 0ms 274 bytes (pipelined: 9)
Jan 04, 2021 23:12:58.245 [0x7f58727fc700] DEBUG - [Transcode] Transcoder segment range: 0 - 7 (7)
Jan 04, 2021 23:12:58.246 [0x7f58827fc700] DEBUG - [Transcode] Transcoder segment range: 0 - 8 (7)
Jan 04, 2021 23:12:58.447 [0x7f58ae14b700] DEBUG - Completed: [192.168.86.48:44262] 206 GET /video/:/transcode/universal/session/2uoirg9ivg9jxx5oholk0ho3/base/00000.ts (11 live) 2311ms 30127752 bytes (pipelined: 1) (range: bytes=0-)
Jan 04, 2021 23:12:58.447 [0x7f58ae14b700] DEBUG - Removed transcode data consumer, active count 1 => 0
Jan 04, 2021 23:12:58.749 [0x7f5870ff9700] DEBUG - Request: [192.168.86.48:44262 (Subnet)] GET /video/:/transcode/universal/session/2uoirg9ivg9jxx5oholk0ho3/base/00001.ts (11 live) Signed-in (range: bytes=0-)
Jan 04, 2021 23:12:58.749 [0x7f5870ff9700] DEBUG - [Transcode/2uoirg9ivg9jxx5oholk0ho3] Asked for segment 1 from session.
Jan 04, 2021 23:12:58.749 [0x7f5870ff9700] DEBUG - [Transcode/2uoirg9ivg9jxx5oholk0ho3] Returning segment 1 from session
Jan 04, 2021 23:12:58.749 [0x7f5870ff9700] DEBUG - Content-Length of /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-2uoirg9ivg9jxx5oholk0ho3-aede732e-f96f-457f-b2da-98b0230794b5/media-00001.ts is 40941324 (of total: 40941324).
Jan 04, 2021 23:12:58.767 [0x7f583b7fe700] DEBUG - [Transcode] Transcoder segment range: 0 - 8 (8)
Jan 04, 2021 23:12:58.768 [0x7f58727fc700] DEBUG - [Transcode] Transcoder segment range: 0 - 9 (8)
Jan 04, 2021 23:12:59.239 [0x7f58ae14b700] DEBUG - Auth: authenticated user 1 as -@gmail.com
Jan 04, 2021 23:12:59.239 [0x7f5870ff9700] DEBUG - Request: [192.168.86.48:44252 (Subnet)] GET /:/timeline?key=%2Flibrary%2Fmetadata%2F114&ratingKey=114&state=buffering&time=1371&duration=6372715&playbackTime=1755&playQueueItemID=111 (11 live) GZIP Signed-in Token (-@gmail.com)
Jan 04, 2021 23:12:59.240 [0x7f5870ff9700] DEBUG - Client [p7nw6sa9rk77hoppfvmgmxqu] reporting timeline state buffering, progress of 1371/6372715ms for guid=, playbackTime=1755ms ratingKey=114 url=, key=/library/metadata/114, containerKey=, metadataId=114, source=
Jan 04, 2021 23:12:59.240 [0x7f5870ff9700] DEBUG - [Now] User is -@gmail.com (ID: 1)
Jan 04, 2021 23:12:59.240 [0x7f5870ff9700] DEBUG - [Now] Device is webOS (LG 75UN6970PUD).
Jan 04, 2021 23:12:59.240 [0x7f5870ff9700] DEBUG - [Now] Profile is Generic
Jan 04, 2021 23:12:59.240 [0x7f5870ff9700] DEBUG - [Now] Updated play state for /library/metadata/114.
Jan 04, 2021 23:12:59.240 [0x7f5870ff9700] DEBUG - Statistics: (p7nw6sa9rk77hoppfvmgmxqu) Reporting active playback in state 2 of type 1 (scrobble: 0) for account 1
Jan 04, 2021 23:12:59.241 [0x7f58ae94c700] DEBUG - Completed: [192.168.86.48:44252] 200 GET /:/timeline?key=%2Flibrary%2Fmetadata%2F114&ratingKey=114&state=buffering&time=1371&duration=6372715&playbackTime=1755&playQueueItemID=111 (11 live) GZIP 2ms 853 bytes (pipelined: 10)
Jan 04, 2021 23:12:59.296 [0x7f58727fc700] DEBUG - [Transcode] Transcoder segment range: 0 - 9 (9)
Jan 04, 2021 23:12:59.296 [0x7f58727fc700] DEBUG - [Transcode] Transcoder segment range: 0 - 10 (9)
Jan 04, 2021 23:12:59.808 [0x7f58827fc700] DEBUG - [Transcode] Transcoder segment range: 0 - 10 (10)
Jan 04, 2021 23:12:59.808 [0x7f5870ff9700] DEBUG - [Transcode] Transcoder segment range: 0 - 11 (10)
Jan 04, 2021 23:13:00.413 [0x7f58af14d700] DEBUG - [Transcode] Transcoder segment range: 0 - 11 (11)
Jan 04, 2021 23:13:00.414 [0x7f58af14d700] DEBUG - [Transcode] Transcoder segment range: 0 - 12 (11)
Jan 04, 2021 23:13:00.455 [0x7f58827fc700] DEBUG - [Transcode] Session 2uoirg9ivg9jxx5oholk0ho3 (3) is throttling
Jan 04, 2021 23:13:00.455 [0x7f583b7fe700] DEBUG - [Transcoder] Throttle - Going into sloth mode.
… it keeps transcoding seemingly the same beginning segments over and over for a while…
Jan 04, 2021 23:15:04.391 [0x7f5870ff9700] ERROR - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] Playback error occurred. Reason: BufferingTimeout, Player took too long buffering, stopping playback
Jan 04, 2021 23:15:04.391 [0x7f5870ff9700] WARN - [Plex for LG] [-@gmail.com:p7nw6sa9rk77hoppfvmgmxqu] [PlaybackSessionController] could not retry, reporting error
…until it just stops trying.
Sometimes the WebOS app will actually run out of memory and crash before Plex times out, which leads me to believe that it’s trying to buffer the whole movie or something.
The issue is reproducible with the legacy WebOS app as well.
Full log and media XML are attached: (File removed)
Let me know if I can provide any other info. I’m not eager to [pre-]transcode my UHD rips to accommodate Plex.
