Where are my changes stored?
Hi all,
I’m preparing to carry out a clean install of Windows, but I’ve spent a long time customising my plex films, mainly changing the poster art, background and the ‘Sort Title’ field.
My C: is my Windows drive where plex is installed and my G: drive is where my media is, but I also have my temp directory located on an F:. However, it’s only the C: that’s going to be re-installed.
I’ve linked an article below that describes the folders you have to copy, however, I recently changed the drive where the media is stored (G) from a 2tb - 6tb and when I did, I had to change all my poster art and Sort Titles even though nothing was touched on the C: drive, which seems to contradict the article below.
I need to make sure I do this right as it will take me hours to sot my media and I really don’t want to have to do that again. Can anyone give me some tips on how to do this?
Those instructions are only applicable if you are keeping the setup the same. i.e. same install folder, same media folders, etc. If you make a change in any of these those instructions won’t be correct. You will need to make modifications, but what they are will depend on what changes you make to the setup.
For moving media to another location, you need to do this, https://support.plex.tv/articles/201154537-move-media-content-to-a-new-location/.
If the steps in that guide are no possible, then you’ll need to modify the database manually instead. This is a bit more complicated but works, [HowTo] Plex database modification - Moving media the right/wrong way.
So it sounds like if I’m going to re-install windows it’s not just as simple as backing up certain folders from my C: drive in order to keep my modifications even if the drive my media is stored on isn’t going to change? The media will stay on the same drive in the same structure with the same drive letter, its only the C drive that will be formatted.
Everything is stored in the Plex data folder, which is located by default on drive C:
You need to backup this data folder and the Plex branch of the windows registry https://support.plex.tv/articles/201539237-backing-up-plex-media-server-data/
I’ve prepared a more detailed description in this post. It might be of use to you: Rebuilding Server
