Server Version#: 1.23.2.4656
Player Version#: 7.18 (iPad)
I created 3 smart playlists using the Web on my computer. On my iPad, I selected each of these playlists, and tapped sync. The sync manager tell me all three playlists are synced.
I disconnect my iPad from WiFi, so now I’m off-line. I can select Downloads and Sync, then my music library, but all I see is a long list of songs. Where are my playlists? How can I select a specific playlist when I’m off-line?
I tried PlexAmp, but it appears PlexAmp uses different storage and cannot see the 8000 songs I’ve downloaded into Plex on my iPad. Since I plan on having a dozen playlists, many with overlap in songs, I chose to use Plex because it doesn’t download songs multiple times like PlexAmp does (if the song is in multiple playlists).
so, any suggestion or trick to selecting a playlist when off-line?
