Please support playlists for mobile sync! I can sync multiple playlists, but when I look at my synced music, only Library and Recommended is there, no Playlists! Please make the synced playlists available to select on mobile.
That’s a known issue on iOS devices if I remember correctly.
Plex will sync the playlist and you’ll be able to access the media while offline – however the mobile Plex app does not show the actual playlist item.
Thanks. This works properly on Android devices?
At least I’m not aware of any issues
Thanks. Do you know if this will be fixed on iOS, or is fixing the issue not possible?
I hope it’ll be fixed at some point but I’m not aware of any ETA.
It used to work on iPhones awhile back, I think one of the iOS or Plex updates changed it. Suggestions?
I suppose it’ll be worth to see if that’s covered by the new experimental feature that’s going to replace sync – from what I understand it’s not yet available for iOS but listed as “coming soon”
