When I pause a Live TV broadcast stream from my HDHomerun Quattro there is a fairly short with which I can resume the stream. If I leave it more than a few mins the stream drops. Can the pause buffer be set anywhere?
There is a network setting but it isn’t suppose to affect Live TV streams. I would be more willing to suspect the client is disconnecting from the server.
Terminate Sessions Paused for Longer Than
You can instruct the server to automatically terminate playback sessions that remain paused for longer than the specified duration (where the value is the number of minutes). This does not affect audio-only sessions or Live TV streams. The default of 0 (zero) means the server will not automatically terminate such paused sessions.
