Where do I find which CPUs that is supported by Plex?
Hi
Im curious if there is a “look-up site” where I can see which cpu that will work with Linux with HW transcoding or not?
Im thinking buying a new Cirrus7 with a Desktop cooling cabinet ( Extreme cooling ) with an Intel Core Ultra 9 285T .
Will put Proxmox Ve on it and run a Linux distro which hopefully support hw transcoding . This processor is from Q1 2025 so I dont know if its too new and drivers aint supported yet or Plex supports it? :slight_smile:
Thank you :slight_smile:
Morphy
It used to depend on whether or not the Intel chip supported Quick Sync, but I’m not sure if that’s still true. I know chipsets that do are good, but I don’t know if there are more included beyond that, now.
Long story short, if you DO see Quick Sync, you’re good.
https://support.plex.tv/articles/115002178853-using-hardware-accelerated-streaming/
So its a yes I guess. Wont buy it if its not supported .
Just want to be 100% sure
Maybe @ChuckPa can confirm.? :grinning_face:
Arrow Lake and Meteor Lake CPUs, using the latter 5.15 / 6.0 + kernels should be identifying it correctly and enumerating it correctly in mainstream Linux.
Pretty sure we tested this some time ago in the 1.32.8 timeframe.
Either way, it will be supported when FFMPEG 6.1 and the new drivers/codecs come online.
Proprietary kernels like Synology (XPEnology) are not likely to have support for it.
Thank you @ChuckPa
Do we know when the new drivers comes online ?
@Morphy
I do not. Chris, team, and I were discussing the schedule before they went off site. I know they’ll discuss more while away. I’ll be briefed upon their return.
@ChuckPa
Ok thank you for your replies :slight_smile:
See that the 6.1 is in Plex beta . Hope for the best :slight_smile:
Oh just need to ask @ChuckPa do I need to install something extra to get it up and running , or is it fine with the latest kernels?
Im on 6.14.11-3
@Morphy
As long as you see the QSV enumerated in /sys/module, follow it through to the PCI bus slot, and see it terminate in the CPU, then you’e got the kernel support you need
[chuck@lizum ~.2001]$ ls -la /sys/module/i915/drivers/
total 0
drwxr-xr-x 2 root root 0 Oct  9 10:24 ./
drwxr-xr-x 7 root root 0 Oct  9 01:27 ../
lrwxrwxrwx 1 root root 0 Oct  9 10:24 pci:i915 -> ../../../bus/pci/drivers/i915/
[chuck@lizum ~.2002]$ ls -la /sys/module/i915/drivers/pci:i915/
total 0
drwxr-xr-x  2 root root    0 Oct  9 01:27 ./
drwxr-xr-x 40 root root    0 Oct  9 01:27 ../
lrwxrwxrwx  1 root root    0 Oct  9 10:24 0000:00:02.0 -> ../../../../devices/pci0000:00/0000:00:02.0/
--w-------  1 root root 4096 Oct  9 10:24 bind
lrwxrwxrwx  1 root root    0 Oct  9 09:01 module -> ../../../../module/i915/
--w-------  1 root root 4096 Oct  9 10:24 new_id
--w-------  1 root root 4096 Oct  9 10:24 remove_id
--w-------  1 root root 4096 Oct  9 01:27 uevent
--w-------  1 root root 4096 Oct  9 10:24 unbind
[chuck@lizum ~.2003]$
Thanks @ChuckPa
Think I will buy it , and give it a go :slight_smile:
Got my build :slight_smile:
I must say - its a BEAST. Running insane fast my new CPU and hw transcoding works so good. Seems that my server is “bored” when I force 5 x 4K movies . Insane :slight_smile: . Havent tried what the cap is. But I should be able to CPU transcode 18 x 1080 p without problems . GPU no clue :slight_smile:
Just want to report back the the Arrowlake is working fine :slight_smile:
@Morphy
Congrats!
When you look in /dev/dri, you see the :partying_face: inodes ? :slight_smile:
When you start PMS (DEBUG loggging), Does it find the GPU?
Yes :slight_smile:
Havent tried enabling the debug, but hw transcoding works . Confirmed via intel_gpu_top :slight_smile:
Plex transcoding menu shows Intel Arrow Lake-U (Intel Graphics) :slight_smile:
