Where to obtain PMS build 4479
Wish I didn’t have to make a new thread, but Chuck your PMs are closed off and you closed the last thread.
Can’t seem to find a download for PMS build 4479 anywhere, and that’s where the apparent fix for the issue is. Would appreciate any info about it. Far as I can tell the docker image listed for PMS is 20 days old and the older version I mentioned in previous thread which doesn’t work, and the same for othe rproviders like Linuxserver repo etc.
Since 4479 has been released, the follow up version: PMS 1.23.0.4497 has been released to PlexPass.
Docker builds are available through normal tagging
The Debian builds do support being installed inside docker containers for those which contain dpkg. apt-get is better as it will automatically pull in available dependencies.
Hrm yeah so i’m running the PMS from plexinc/pms-docker, but the only update it seems to want to pull down is the 4392 build?
[root@lizum docker]# ./dockerplex
plex
plex
Error response from daemon: No such container: plex
Error: No such container: plex
Untagged: plexinc/pms-docker:plexpass
Untagged: plexinc/pms-docker@sha256:8aeb4a982ea564ad309861dd251cd9e218aac3f4e4d3da21375568341be1b16f
Deleted: sha256:bd2a705539fb8e5a051e7754a97e7345e542e6e1aa374bf6d7cff0c2601034bd
Deleted: sha256:cd9edf380b4fb57f6e1b0abfe6d7954e699075602a6668fa37ad9c842cff1efd
Deleted: sha256:f92d453744abb8c52af7fa92d2237cedf03677ef92f08588013437155633c3c0
Deleted: sha256:2f5655bc324df8f211364c70328e7f402cb4c631a272e188ba2483f1b469f360
Deleted: sha256:9de65d1e8b2782409b2420bf9347003a43e91bb65c1e4c8fbd7d098d6234f359
Deleted: sha256:e0f8e3acb2bf7fe9384463ae7009179d299b211e7cf17c2bf9d8e5e248cfe5b0
Deleted: sha256:0e64bafdc7ee828d0f3995bebfa388ced52a625ad2969eeb569f4a83db56d505
Unable to find image 'plexinc/pms-docker:plexpass' locally
plexpass: Pulling from plexinc/pms-docker
a70d879fa598: Pull complete
c4394a92d1f8: Pull complete
10e6159c56c0: Pull complete
d1042fe57e96: Pull complete
ac5317c7b384: Pull complete
47414e89d67b: Pull complete
Digest: sha256:8aeb4a982ea564ad309861dd251cd9e218aac3f4e4d3da21375568341be1b16f
Status: Downloaded newer image for plexinc/pms-docker:plexpass
0c8ef42a8af19ae7df7cf009c89b1dbde7d0e8c14ac809412e633a83f80bc406
[root@lizum docker]# docker start plex
plex
[root@lizum docker]# docker stop plex
plex
[root@lizum docker]# vi dockerplex
[root@lizum docker]# docker images
REPOSITORY           TAG        IMAGE ID       CREATED        SIZE
plexinc/pms-docker   plexpass   bd2a705539fb   4 weeks ago    408MB
hello-world          latest     d1165f221234   2 months ago   13.3kB
Yeah ended up needing to change the version from ‘latest’ to ‘plexpass’. Assumed it would be like the other containers and the latest tag would simply determine eligibility before applying update. Honestly forget that there is even two seperate builds still, as can’t imagine bothering with Plex without the Plex Pass benefits.
Anyways, got the latest build and it is indeed working once more thankfully. Fingers crossed smooth sailing with it now.
Both versions have the same features. There is no “Plex Pass FEATURES” build.
When you add the plexpass tag, you download from the PlexPass Beta channel.
When you add latest (or leave blank), you download the Public version.
Plex Pass features are attached to your account not the code.
