Where to report bugs?
Is there a dedicated form to report bugs or anything? I’m seeing some that really don’t seem to deserve a dedicated thread here, but I’m failing to find any info on how to report bugs. Small things like how if you bring up your list of libraries and it’s fairly long, it won’t scroll all the way to the bottom of it.
Additionally, reordering my libraries seems to have no effect on my home screen. I can’t figure out any way to change what shows on the home screen or the order it is displayed. Not sure if bug or just not yet implemented.
Reordering libraries from My Libraries will reorder them on the Home screen, but you may need to exit the app and open it again for the changes to take effect. It may occur automatically after some period of time, but I’ve just closed and reopened to force it thus far.
You’re right, the order is respected after closing and reopening the app. Definitely a bug then!
