Hello, first off I hope that I am posting this in the correct forum/topic, apologies if I did not. I have a server running OpenSUSE Leap 15 and would like to install Plex Media Server onto it. I have done some digging and found that PMS isn’t really natively supported for SUSE but also noticed some posts saying it works with SUSE just by using one of the images for the other distros. Would anyone be able to tell me the best distro image to use for SUSE as well as where to get it if its not on the downloads page for Plex?
Thanks!
You only have two possible choices of the three available for Linux. Fedora or CentOS. Pick one and try it. If it doesn’t work, remove it and try the other.
If I may augment herer?
OpenSuse support is marginal at best right now.
I have added full support for it. It’s in the Forum Preview
The same Redhat RPM works for OpenSuse now for all systems which use systemd as pid 1.
Awesome! Thank you, do I just come to this post whenever there is an update? This seems to not be the latest version.
No. At some point (as soon as engineering makes fully ‘Production’ release) It will next show in Plex Pass beta. After that, it will be normal regular production for all.
