Server Version#:4.76.1
For some unknown reason, my Plex Media Server on my Windows PC started display Unauthorized Access’ for my Movie and TV Libraries on my local hard drives.
Not finding any solution, I uninstalled Plex and reinstalled it.
Now I am not displaying ANY of my local libraries nor are there any visible way to add them.
When I open Plex on my PC, the Home page has Live TV, Movies & Shows, and Music.
I have gone through Settings and all the options but can find no way to Create and/or Add the local libraries (or find out if I still have the ‘Unauthorized Access’ problem).
Any help would be greatly appreciated.
PS I have been using Plex for a few years and this is the first problem I am having with it.
See Why am I locked out of Server Settings and how do I get in? | Plex Support and the registry files that need deleted to reclaim the server
Thanks. Removing the Items from the registry got the local libraries categories to be displayed again.
However, I am back to the original problem. When i click on the local Libraries (I have one for Movies and one for TVShows), I get the ‘Not Authorized You do not have access to this server.’
I am using the same computer that I have for the last few years without problems. Not sure why this is showing up or how to fix it.
Did you log back into the server?
Thank you. That seems to have fixed it.
Something so simple and easy to overlook.
