So, my plex is setup on my computer (windows) where I can easily play original quality, however, on my friend’s macbook pro connected to my local network, plex can’t play videos on original quality, so he has to convert. What could be the issue?
If you check this post you can find out why its trans-coding which will direct you as to why it cant direct play.
Maybe Audio Codec issue? Maybe Video coded issue?
