TLDR - Is the Synology 218 play underpowered to transcode ?
New to all this and still figuring things out. I’ve just bought a Synology 218 play and have set up my Plex server on it. I’m testing with a movie I’ve chucked on to see it’s working ok and it’s not , it won’t playback on my phone (It takes around 45 secs to a 1 minute to load up and buffers frequently.) Whilst most of my use will be on the same network, I do travel so I want to be able to use this in 4g.
Not sure what info might be needed to help me but…
As far as I can tell the client and the server are the latest version, as is the Synology.
I’m using the apps natively, not using Docker.
Home bandwidth is around 30mbits, I’m using 4g on the phone and it’s around 13mbits.
The file is an .mkv 1080p movie, info from Plex as folllows
- Codec H264
- Bitrate 8028 kbps
- Bit Depth 8
- Chroma Location left
- Chroma Subsampling 4:2:0
- Coded Height 1040
- Coded Width 1920
- Frame Rate 23.976 fps
- Height 1040
- Level 4.1
- Profile high
I’ve checked the logs as per this article https://support.plex.tv/articles/201575036-why-is-my-video-stream-buffering/ and I can see that the Synology is struggling…(quick cust and paste of a small section)
Jan 27, 2020 18:01:31.755 [0x7f49fc51d0] VERBOSE - * speed => 0.8
Jan 27, 2020 18:01:32.340 [0x7f16b7d1d0] VERBOSE - * speed => 0.5
Jan 27, 2020 18:01:32.857 [0x7f485671d0] VERBOSE - * speed => 1.4
Jan 27, 2020 18:01:34.075 [0x7f16b7d1d0] VERBOSE - * speed => 0.1
Jan 27, 2020 18:02:54.332 [0x7f4bfff1d0] VERBOSE - * speed => 0.0
Jan 27, 2020 18:02:55.232 [0x7f9117c1d0] VERBOSE - * speed => 0.0
Jan 27, 2020 18:02:56.005 [0x7f4bfff1d0] VERBOSE - * speed => 0.0
Jan 27, 2020 18:02:56.691 [0x7f16b7d1d0] VERBOSE - * speed => 0.4
Jan 27, 2020 18:02:57.192 [0x7f159e91d0] VERBOSE - * speed => 0.9
Jan 27, 2020 18:03:00.331 [0x7f156fb1d0] VERBOSE - * speed => 0.1
Jan 27, 2020 18:03:00.851 [0x7f49fc51d0] VERBOSE - * speed => 0.7
Jan 27, 2020 18:03:01.550 [0x7f932dd1d0] VERBOSE - * speed => 0.7
Jan 27, 2020 18:03:02.232 [0x7f4bfff1d0] VERBOSE - * speed => 0.1
Jan 27, 2020 18:03:02.734 [0x7f156fb1d0] VERBOSE - * speed => 0.4
Jan 27, 2020 18:03:03.259 [0x7f49fc51d0] VERBOSE - * speed => 0.5
Jan 27, 2020 18:03:09.330 [0x7f16b7d1d0] VERBOSE - * speed => 0.0
Jan 27, 2020 18:03:10.651 [0x7f932dd1d0] VERBOSE - * speed => 0.0
Jan 27, 2020 18:03:11.510 [0x7f4a88f1d0] VERBOSE - * speed => 0.1
Jan 27, 2020 18:03:11.988 [0x7f49fc51d0] VERBOSE - * speed => 0.4
Jan 27, 2020 18:03:12.517 [0x7f156fb1d0] VERBOSE - * speed => 0.5
Jan 27, 2020 18:03:13.031 [0x7f159e91d0] VERBOSE - * speed => 0.2
Jan 27, 2020 18:03:13.701 [0x7f16b7d1d0] VERBOSE - * speed => 0.8
Jan 27, 2020 18:03:14.093 [0x7f4bfff1d0] VERBOSE - * speed => 0.2
Jan 27, 2020 18:03:14.679 [0x7f4a88f1d0] VERBOSE - * speed => 0.5
Jan 27, 2020 18:03:17.617 [0x7f49fc51d0] VERBOSE - * speed => 0.8
Jan 27, 2020 18:03:18.126 [0x7f159e91d0] VERBOSE - * speed => 0.0
Jan 27, 2020 18:03:18.310 [0x7f16b7d1d0] VERBOSE - * speed => 0.5
Jan 27, 2020 18:03:18.833 [0x7f4bfff1d0] VERBOSE - * speed => 0.5
Jan 27, 2020 18:03:19.408 [0x7f177351d0] VERBOSE - * speed => 0.5
So… Is my Synology underpowered for this task and therefore I need more grunt power for my server? Or am I doing something else wrong?
Thanks in advance
Server Version#: Version 4.12.3 / 1.18.4.2171-ac2afe5f8
Player Version#:7.27.0.15018
