Server Version#: 1.18.5.2309-f5213a238
Player Version#: 1.20.0.1406-f47a81b7
Hi there.
As you can see here
Plex is showing me the same album twice, with different tracks associated to each of them.
How can I fix this?
Thanks,
F.
Hi there.
As you can see here
How can I fix this?
Thanks,
F.
assuming all files are in the same album folder, you can also use ‘fix match’ on each separate album and match them to the same album
Generally the cause is from what I have seen is that there might be a slight discrepancy in the embedded metadata. Like the album artist might be different or something easily missed like an extra space in a field or something making them not match
The Plex Dance solved my issue. I was already sure that the tags were 100% OK, as I had just hours before passed the album through MusicBrainz Picard. So just following the 7 magic steps led to the solution!
Thanks!
F.
